1st real drive
- 1st Gear
1st real drive
had the first real drive of the car today with the new drc, felt SO much different ! Nice and softish when on m way and nice and firm on the twisty stuff !!!
Quick question the car feel much higher than befor on the front, given i have SS+ can someone tell me the mesurments and how to measure the correct hight ? Im sure i saw it on here somewhere befor but cant find it !!
- 1st Gear
RE: 1st real drive
P_G id have money you know th answer to this ! Eather you or Sonny !
RE: 1st real drive
I'll measure mine tomorrow if no-one answers, but won't be home till evening
John - when working properly, the front does appear much higher than the rear. As the system loses pressure it tries to adjust, and the first thing to happen is that the font drops - on this basis, you're more likely to notice a change at the front when sorted...
2007 Daytona RS4 Avant
RE: 1st real drive
Cheers Dom !!!
As i have no idea what it was like befor, it was broke when i got it, i have nothing to compare it to !
We all struggled to explain that the car had the SS+ option, but as germany sent someone over to fit it i would of thorght it was correct, unless the guy didnt check the shocks were the SS+ ones or he was not aware ?
997 turbo (uk)
Khan Range Rover TD V8 (UK)
RS4 (Spain)
CLK Convertable (Spain)
Ferrari 458 on order (now sold my order) !
RS4 (Spain)
RE: 1st real drive
Does it just need time to settle maybe?
RE: 1st real drive
DRC is a pressurised system, so how can it settle, that would mean losing pressure, which means its leaked, which means it broken?
RE: 1st real drive
Ah right, I read somewhere that it needed time to settle.
It was here
http://www.rs246.com/index.php?name=PNp ... drc+settle
But the source was a dealer so......
My mistake.
It was here
My mistake.
Re: RE: 1st real drive
Im running after market suspension so I no point in me taking measurements. the rears will sit lower than the front but only by 3mm on std suspension, I thinkjohninspain2 wrote:P_G id have money you know th answer to this ! Eather you or Sonny !
SS+ is 10m lower than normal suspension.
So hopefully someone who has SS+ will be kind enough to go out side and take some measurements for you
As for settle, im sure the system will settle as there still springs, and the spring will compress...however im not 100% myself...any one confirm
- 1st Gear
RE: Re: RE: 1st real drive
anyone ?
Not having SS+ John I could only theorise. Cars that 'settle' are like sonny says usually the springs settling so yes it can drop. However there is also an argument to say that if your DRC was broken in the first place, there is less fluid in them and the shocks have compressed to their lowest point making the car lower than a standard filled and correctly pressurised system.
See if there is any change over the next few weeks with some driving and keep us posted.
- 1st Gear
- 1st Gear
Users browsing this forum: No registered users and 100 guests
