RS4 Ceramic Brakes-Rotors don't fit
RE: RS4 Ceramic Brakes-Rotors don
OK now I could be wrong but I think the Ceramics came in 2 sizes, one for 18'' wheels the other for 19'' wheels. maybe you have the other other, however cant see that effecting the hub circumference.
- Virdee Autos
- Trader (Expired)
Paul, glad to hear you recieved it. Thanks for the kind words
Hopefully it'll be of some assistance.
Virdee Autos ~ 07950-526592
The CD-ROM was very helpful. Unfortunately, they are the wrong discs (part number 4E0 615 301 AA/4E0 615 302C). I'm guessing they are for the A8/S8. Or maybe what Sonny posted is correct? Can anyone verify this?
Will have to go a different route and will keep everybody posted. Thanks.
sorry to hear this, I have been wondering how you have been getting on, did you purchase the discs new from Audi or second hand, any way of exchanging them?
I received the brake set from a friend overseas. It came off of a wrecked Audi, not an RS4 apparently.
I am still trying to get a set for the RS4, the main reason being the weight savings. We track the car quite frequently and it does very well but the weight is fairly evident going throught corners. That is also the reason we are trying to acquire the OEM Euro seats.
Thanks for the concern. I'll post any updates.
OK yes it is a major weight saving, and most ppl will rip some ones arm off if they had a set of ceramics up for sale lol best of luck.
Re: RE: RS4 Ceramic Brakes-Rotors don
could you please explain how to do it with Vag-com ?sonny wrote:According to my Audi Tech, you will also have to set it up using VAG-COM. the ABS will have to be calibrated to the wipers (so break pads pulsate in the wet when wiper arms activated).
coding for standard rotors is 0004533
what is it for ceramic rotors ?
thank you in advance
RE: Re: RE: RS4 Ceramic Brakes-Rotors don
"Once fitted the ABS control will need to be re-coded so it knows ceramic brakes are fitted. This can only be carried out at an Audi centre."
This is what my audi Tech said. so not sure if he means VAG-COM. I will have to ask him when he goes back to work.
Anto I sent you mail already, but for anyone else you wants to carry out this conversion coding is:AntoRS4 wrote:could you please explain how to do it with Vag-com ?sonny wrote:According to my Audi Tech, you will also have to set it up using VAG-COM. the ABS will have to be calibrated to the wipers (so break pads pulsate in the wet when wiper arms activated).
0004533 Stock Rotors
0004534 Ceramic Rotors
tabs wrote:Anto I sent you mail already, but for anyone else you wants to carry out this conversion coding is:AntoRS4 wrote:could you please explain how to do it with Vag-com ?sonny wrote:According to my Audi Tech, you will also have to set it up using VAG-COM. the ABS will have to be calibrated to the wipers (so break pads pulsate in the wet when wiper arms activated).
thank you
0004534 seems to be not the correct one
somebody here with ceramic rotors fitted and vag-com ?
if yes please select 3-abs and read coding
thank you
thank you
Sorry I didn't get back to you earlier. Upgrade to new operating system wasn't very smooth so my computer has been down. I usually don't like to bad-mouth anybody, but let's just say the name starts with "W" and ends with "7".
Here are the coding instructions from the CD-ROM:
Coding
Possible ESP versions:
Steel Brakes
Brakes in airbag adaptation channel 51: 22
ESP version: 4533
Ceramic Brakes
Brakes in airbag adaptation channel 51: 20
ESP version: 4534
Hope this helps.
Coding
Steel Brakes
ESP version: 4533
Ceramic Brakes
ESP version: 4534
Hope this helps.
Just a side note. Found out the Ceramic brakes are for a A8/S8. So if anybody is interested.....
Re: RS4 Ceramic Brakes-Rotors don't fit
it workspaku wrote:Sorry I didn't get back to you earlier. Upgrade to new operating system wasn't very smooth so my computer has been down. I usually don't like to bad-mouth anybody, but let's just say the name starts with "W" and ends with "7".
Coding
Steel Brakes
ESP version: 4533
Ceramic Brakes
ESP version: 4534
Hope this helps.
thank you paku
RE: Re: RS4 Ceramic Brakes-Rotors don
Could it be as simple as replacing the Hat to get the correct offset??
Users browsing this forum: QuRace and 158 guests
