Trouble with Clutch
Denyy_787
Trouble with Clutch
Post by Denyy_787 » Tue Apr 14, 2009 8:51 pm
Hello Folks!
Just checking how many of you have had trouble with their clutch and have had hydraulic hose pipe changed.
Kind of weird, I went to the shop this morning, left my car, (couldn't change anymore, clutch didn't allow me to do it, drove in third gear for miles); obviously once the the guy at Audi tried the car it was just fine. :(
Anyhow, he called me afterwards and he said he was going to replace the above first, then we'd have gone from there.
I'm just trying to find out if you guys in uk have had Audi honoured this cost and if so is there anything in writing?
Being Audi represented and imported by Autogerma (Italy), it's always a mess when you deal with these stuff especially when is related to warranty and bu....hit!
Thanks for your help and for sharing.
Daniele
Marcus-RS4
RE: Trouble with Clutch
Post by Marcus-RS4 » Tue Apr 14, 2009 8:54 pm
Had mine done under warranty, no hassle whatsoever!
Its a common problem and I am sure many on here have had it done already.. as far as writing is concerned - I have the service schedule if that helps?
jackwood
Post by jackwood » Wed Apr 15, 2009 12:49 am
Had mine done twice under warrenty.
klauster
Post by klauster » Wed Apr 15, 2009 8:07 am
I had mine in to be looked at and they told me it was normal for it to be stiff selecting gears when cold... mine tends to be ok when warmed up
Denyy_787
Post by Denyy_787 » Fri Apr 17, 2009 10:21 am
In the end they're trying to replace the f....ing hose pipe and during the process I was told that the cost would have been around 600 euro and that they wouldn't cover it.
Anything you guys have in writing that could help....it's a factory defect, isn't it?
Daniele
ADR14N
Post by ADR14N » Fri Apr 17, 2009 11:22 am
Had trouble selecting gears from cold. Could not get 1st or 2nd, reverse also a problem. Watford looked at it. Replaced clutch and pipe. Was good for about 2 months then went back to difficult to select from cold. Took the car to Camberley. They found the input shaft full of rust. Cleaned and greased, refitted. Car has been perfect for last 4 months.
:lol:
Denyy_787
Post by Denyy_787 » Fri Apr 17, 2009 11:51 am
Guys, just found out that there's a TSB out there....anyone can help in finding this doc?
Thanks for your help!!!!
ghoonk
Post by ghoonk » Fri Apr 17, 2009 12:41 pm
I'm looking for this TSB myself -- I just need the correct part number so I can get my Audi specialist to do the replacement. Is it just a clutch line, or is it a replacement for something bigger?
2006 Sprint Blue Audi RS4 : photography by lifegauge
Denyy_787
Post by Denyy_787 » Fri Apr 17, 2009 12:46 pm
8E1-721-465AQ TUBE Found everything on Audi Forum
http://forums.audiworld.com/showthread. ... ght=clutch
ghoonk
Post by ghoonk » Fri Apr 17, 2009 12:47 pm
Thanks, mate. I've been searching on quattroworld for this, but to no avail
Users browsing this forum: vailpilgrim, Zyox and 313 guests
