Flickering Head light
Jog
Post by Jog » Sun Mar 08, 2009 10:31 pm
Advice required please guys. I pulled away from the office a few weeks ago and noticed the NS headlight flickering. After 20 seconds or so, it went out and the blown bulb indicator appeared on the DIS. When I got home I turned off the ignition and then switched on again and the light works normally with nothing on the DIS. It has flickered a few times since but has not gone out. Is the bulb on the way out or could it be something else??
Mark
Current B8 2015 RS4 - Misano
2010-2017 2x997, 3xRRS
2007-2010 B7 2006 RS4 - Sprint
2003-2007 v6 TT - Misano
pippyrips
RE: Flickering Head light
Post by pippyrips » Sun Mar 08, 2009 10:49 pm
Sounds very much like the symptoms I had, cured by two new headlight ecu's.
I still have a sneaky feeling it was just a loose conection but Audi's approach of replacing bits one by one got it on the 3rd attempt.
When mine was playing up, turning the lights off and on again worked for a while.
bn8959
Post by bn8959 » Mon Mar 09, 2009 12:02 am
Ive had this happen on my old Mondeo. Flickering then it going out. I left it too long (until it stopped working alltogether) and I had to replace the bulb and the ballast (the device that converts 12v up to 60ish volts with a 20kv kick start needed for HID bulbs - the 'xenon' type we have) - so Im not sure whether the ballast went wrong and blew the bulb; or more likely the bulb was wearing out and it blew the ballast, presumably as it worked too hard trying to keep the bulb alight.
I suggest you see if Audi will fix it under warranty asap, otherwise start by replacing the bulb asap - very expensive from the manufacturer (£150+), I got mine from hids4u.co.uk for about £50. I think the type needed is D2S - but double check that!
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Jog
Post by Jog » Mon Mar 09, 2009 10:23 pm
Cheers guys, I shall get her looked at.
Mark
Users browsing this forum: Google Adsense [Bot] and 236 guests
