Do I need my radio PIN if I disconnect te battery for B7 RS4
ducatiman
Post by ducatiman » Sat Feb 14, 2009 12:18 pm
I'm planning on remapping my ECU and part of the process entails disconnecting the battery. Unfortunately I don't have my radio PIN. The manual says that in some models it shouldn't be a problem if the unit is still in the same car so therefore it can learn w/c putting back the PIN. Is this right?
Thanks folks
Ozrs4
RE: Do I need my radio PIN if I disconnect te battery for B7
Post by Ozrs4 » Sat Feb 14, 2009 12:51 pm
That's correct. You only need the pin if the RSN-E unit is out of the car or disconnected from wiring loom. I found this out when I was doing the video-in-motion hack.
2007 RS4 B7 - Phantom black saloon
Andyuk911
Post by Andyuk911 » Sat Feb 14, 2009 1:52 pm
When I added the Bluetooth module, I disconnect the RSN-E and it did not need a pin when reconnected.
RS4 Avant - Sold Aug 2009
rAudiguy
Post by rAudiguy » Sat Feb 14, 2009 2:14 pm
You do not need the pin to reconnect it even if you completely take it out of the car! it's coded to the car so knows it is the right unit for the car.
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
PetrolDave
Post by PetrolDave » Sat Feb 14, 2009 5:19 pm
You don't need the PIN unless you do something like the VIM hack which "messes up" the non-volatile memory in the RNS-E.
ducatiman
Post by ducatiman » Sun Feb 15, 2009 12:00 am
Thanks guys. Thanks a million for the feedback.
Users browsing this forum: No registered users and 83 guests
