Have just returned home from a 1 month business trip to dramatically lower temperatures. The RS4 has been garaged during my trip. On return, the red tyre pressure warning light is illuminated on firing the engine - in the DIS. I've checked tyre pressures and all seem OK, but cannot seem to access the DIS to reset the system.
A short tap of the SET button does nothing, and leaves the red warning symbol in place. A longer press brings up the laptimer, but whatever I try, I cannot seem to access the DIS menu.
All suggestions welcome.
Cheers, Mark
Tyre Pressure Warning
Have tried driving round a bit - well, for 3 days since I got back. Still no joy. Really would like to avoid a trip to the stealers, if I can help it.
I think it must be something to do with a sensor "misread", due to the car being sat there while the temperature outside dropped.
Just had a thought - does the DIS only allow access to the menu when the engine is not running? The warning light only lights up after the engine is running - have not yet tried the DIS before starting.
Cheers, Mark
Cheers, Mark
You need to switch ignition off, then put ignition on but do not start the car. Press set, keep it pressed. The warning will flash 3 times and then should bring up the menu. Either that or press set, leave the warning to beep 3 times, then press set again to bring up the menu.
R
R
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Users browsing this forum: No registered users and 112 guests
