Tyre Pressure Warning
Bradders
Post by Bradders » Tue Nov 13, 2007 2:52 pm
Have just returned home from a 1 month business trip to dramatically lower temperatures. The RS4 has been garaged during my trip. On return, the red tyre pressure warning light is illuminated on firing the engine - in the DIS. I've checked tyre pressures and all seem OK, but cannot seem to access the DIS to reset the system.
A short tap of the SET button does nothing, and leaves the red warning symbol in place. A longer press brings up the laptimer, but whatever I try, I cannot seem to access the DIS menu.
All suggestions welcome.
Cheers, Mark
crispy
Post by crispy » Tue Nov 13, 2007 3:04 pm
I have no idea, so this is purely a guess ->
Maybe try driving the car for a bit and see what happens - something could need to charge up
If you have checked them manually, then I wouldn't worry too much about the tyres.
No idea what you can't get into the DIS with the set button though....
Bradders
Post by Bradders » Tue Nov 13, 2007 3:14 pm
Have tried driving round a bit - well, for 3 days since I got back. Still no joy. Really would like to avoid a trip to the stealers, if I can help it.
I think it must be something to do with a sensor "misread", due to the car being sat there while the temperature outside dropped.
Just had a thought - does the DIS only allow access to the menu when the engine is not running? The warning light only lights up after the engine is running - have not yet tried the DIS before starting.
Cheers, Mark
tartan_rob
Post by tartan_rob » Tue Nov 13, 2007 3:48 pm
You need to switch ignition off, then put ignition on but do not start the car. Press set, keep it pressed. The warning will flash 3 times and then should bring up the menu. Either that or press set, leave the warning to beep 3 times, then press set again to bring up the menu.
R
2017 Kawasaki Z1000
2014 RS6
2014 S1
Bradders
Post by Bradders » Tue Nov 13, 2007 3:51 pm
Bingo. Thanks for your help Rob.
Cheers, Mark
Users browsing this forum: No registered users and 172 guests
