Mines developed the Clutch Issue
After 2600 miles mines developed the clutch issue.... Gets a bit sticky and changing from first to second is an absolute nightmare sometimes. Car can be described as lurching etc when engaging....
If anyone can let me know the exact problem or part so I can let the service guys at Maidstone know.
Also going to get the bluetooth sorted which hasnt worked since the day it was delivered!
06 RS4 B7 Ebony Black
- fredfunk1975
RE: Mines developed the Clutch Issue
http://rs246.com/index.php?name=PNphpBB ... ic&t=54673
Try this, seems to be more and more common.
Although I haven't noticed the sticky pedal, when I floor mine in 2nd it is sometimes juddery ( almost kangarooing) I had put it down to my piss poor driving but could it be the same issue?
Don't be so sure, now I have started to push mine on, I notice the same thing, but have put it down to ESP kicking in as it will only do it when changing from 1st to 2nd under hard/full load.....usually too busy watching the road to see if the ESP light is flashing though
- fredfunk1975
Mine does it the same simple1, its bloody annoying when you are hard on the gas and it stops for a second then decides to kick in again!
I havent noticed any lights flashing on the dash when doing it though. I put it down to the electronics limiting the engine grunt going to the gear box!???? Could be talking utter bo##*** though!
It did it in the S4 as well
Tried it again this morning, no ESP lights flashing....!?!
Def ESP.. the light came on! I think it was mainly due to being a stupidly high speed hump... one of those ones which you hit and then drop off literally! As the back axle came off it dropped quite hard where the fronts were still powering ahead. Im guessing that caused it. But the esp light was flashing like a fairy light!
deansheehan
I had the clutch problem and have had the pipe replaced - works like a treat now. Before I was having the odd problem with the clutch feeling incredibly stiff but more frequently the clutch peddle, and hence engaging, taking an age and this caught me out a couple of times with some nasty over-revs.
I have also noticed the 2nd gear power absence and can't remember whether it was on this forum or rs6 forum that there was a discussion about the ASR setting of ESP. I've always poo poo'd the people who said it was ESP cutting in because I've never seen the ESP light when I've felt this power absence then surge but I then tried turning off the ASR (first stage of ESP with a single push rather than 3 second full off) and did a standing start - pefect start this time and I actually noticed the wheels squeel a little which I've never heard with the ESP fully on. I tired a second standing start with the ASR back on and got the 2nd gear lurch.
So, I now beleive the 2nd gear power absence/surge is related to the ASR.
My wife says she knows to brace herself now when she sees me reach for the ESP button at the lights
cheers,
- Dean
cheers,
- Dean
Your clutch issue!!
My dealership received a bigger hydraulic line for the clutch, Audi has finally agreed that the original line is not big enough, and was installed improperly. After getting mine replaced my clutch is engaging oh so sweet, I feel like I am driving a completely different vehicle now.
Good luck to you and hope Audi sends you the right part!!
Users browsing this forum: No registered users and 212 guests
