S6 AAN Intake hose anti-collapse rings
Posted: Sat Nov 03, 2007 9:11 pm
I have recently fitted anti-collapse rings to my 97 S6 AAN MAF to Turbo intake hose and just wanted to share with you the circumference sizes of the pieces of stainless steel wire needed.
The sizes, from top to bottom are:
1) 262.67mm
2) 251.36mm
3) 243.50mm
4) 241.93mm
5) 235.65mm
Cut 5 bits of rod/wire to this length, bend and TIG together to form the 5x rings you need.
The rings I made where round shaped by hand, where made from 2.5mm TIG welding filler rod and TIG welded together with the TIG set to 15Amps.
Each ring fitted in quite easily by removing the hose and heating the complete thing in HOT water and adding a little washing up liquid to the equation.
When you remove the hose you will clearly see which rubber rings they fit into. They don't go in the first three rings at the top!! they are solid, they fit into the next 5 down
1) 262.67mm
2) 251.36mm
3) 243.50mm
4) 241.93mm
5) 235.65mm
