Urgent help needed regarding HALDEX controller....Vagcom
Posted: Sun Mar 02, 2008 8:10 pm
by B7B7B7
Address 01: Engine Labels: 8N0-906-018.LBL
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 80179
WAUZZZ8LX21002834 AUZ7Z0A1887012
2 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
Readiness: 0000 0000
Address 22: AWD Labels: 02D-900-554.LBL
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 56: Radio Labels: None
Part No: 8L0 035 195 H
Component: symphony II NP2 0151
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
44-10 - Short Circuit - Intermittent
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
Any 1 any ideas...... most importantly the haldex controll unit?????
RE: Urgent help needed regarding HALDEX controller....Vagcom
Posted: Fri Mar 14, 2008 11:17 am
by p1tse
not sure what it means, but haldex is what controls the front wheels and rear wheels. just upgrade to a performance haldex to give a better split for the rear wheels
