Giving good head
Posted: Sun Oct 28, 2007 11:31 pm
by simons3
What is the standard head/valves/cam good for in Bhp before this start to crack and bend etc???
cheers :notworthy:
RE: Giving good head
Posted: Mon Oct 29, 2007 7:12 pm
by simons3
Around 400Bhp Simon.
Ah really Simon.
Well thanks for you post mate.
No problem, anytime.
Posted: Mon Oct 29, 2007 9:27 pm
by ChrisRS4
'Tis your vlaves that you need to worry about. I've heard of them going on highly strung remaped K04'd S3/TT/LCRs (so about 275-280bhp). I've been running standard valves for a year at 340bhp and no issues yet, other than a little nervousness on my part. Usually more to do with high rpms than power levels.
Posted: Tue Oct 30, 2007 12:41 pm
by simons3
Thanks Chris.
Posted: Sun Nov 04, 2007 9:15 pm
by The_Nich
stock valves are good for really high power - it is the tuners philosophy on how high EGTs should be that will cause valves to go. A tuned car at 500bhp will not run higher egts than a tuned car at 280bhp. The valves will only bend whn you try to over rev the engines so the springs cannot close the valve before the piston comes up!
Cracks are caused by too high heat - egts - or some muppet putting plugs in too tight so the alloy head cracks with the extra tension by the steel plug.
