Wheel spacers..... how wide can i go on the rear????
Posted: Mon Oct 01, 2007 8:26 am
by B7B7B7
Looking to get some H&R wheels spacers... was thinking 15mm front, 35mm rear to get a wider stance..... my cars on 19s and isnt lowered.... will spacers through out handling etc???? will the wheels rub???
RE: Wheel spacers..... how wide can i go on the rear????
Posted: Mon Oct 01, 2007 1:10 pm
by ChrisRS4
If you're thinking about 35mm each side then you'll have major issues. 15/16mm at the rear is about the limit. 10mm each for the fronts (15mm's look daft - been there, done it, changed back).
Posted: Mon Oct 01, 2007 1:11 pm
by ChrisRS4
And don't forget you'll need longr whel bolts. Standard bolts have 27mm threads, so you'll need 27mm + what ever spacer size you're using.
Posted: Mon Oct 01, 2007 6:43 pm
by B7B7B7
How come i will have issues??? so 10 front and 15 back??? will that make a big difference in looks as at the moment with 19s (not lowered) it looks daft as they are set right into the arch...plus they have a deep lip so it looks worse.... if you look on the post i did earlier 'new rims' youll see what i mean....
Posted: Mon Oct 01, 2007 7:19 pm
by ChrisRS4
Yeah Scott, I did have a look at those pics and it made me wonder what width/offset those things are.
If you go too extreme with the spacers you'll end up rubbing the tyres on the arches everytime you try and push it round a corner.
Posted: Mon Oct 01, 2007 9:05 pm
by B7B7B7
think there et 40??? not sure. They were from potn and they advised on the best size and correct pcd as i origionally wanted a 9j rim on the rear to make it a touch wider.... From yor pic i can see ya front wheels are nearly in line with your arches which looks really good and is the look i wanted.... what set up have you got ie wheel size, off set / spacers???? cheers. scott
