Air mass meter?
Posted: Tue Sep 19, 2006 3:00 pm
by S3MXLA
Hello All,
Can anyone help with one of those niggly running problems that it appears all the 1.8T VAG group engines will suffer from at some point.
Mine is a 2000 210bhp car and has over the last couple of months developed a problem. The turbo seems to have gradually been offering less boast in general, and on occasion spluttered badly, or gaving a huge surge of power around the 5K mark! (Wish it was like that all the time)
This was diagnosed (VAG technician) as a secondary air leak. I've just had 2 pipes replaced at the front of the engine. Cured??
No not really the car now really dosen't run at all. The symptom is very similar to faulty injectors in the ol VR6 engines. It basically misses constantly.
The cure (VAG technician) a new air mass meter. Will this work?
Any body had this trouble?
Mark
RE: Air mass meter?
Posted: Tue Sep 19, 2006 9:07 pm
by neckarsulm
Sounds possible, air mass meter has been replaced on mine (now 97k miles) and is a 2001 model and it's very common.
I'd run a diagnostic check using VAG COM, if there is nothing logged it's usually the air mass meter but I'd double check by looking at the signal is Measuring Blocks to check that it's measuring the right amount of air.
You should be able to fit one yourself and the cost is around £80 from VW/Audi.
RE: Air mass meter?
Posted: Wed Sep 20, 2006 12:24 pm
by S3MXLA
Thanks for your advice, I had the air mass meter replaced yesterday. and boy what a difference.
The car now has a turbo again!!! :)
