What does this dash light mean?
Posted: Wed Sep 06, 2006 9:50 am
by S3_guy
I've just bought a 225bhp S3 and this dash light has just appaered. Car appears to be driving fine with no loss in power or strange noises. It stays on constantly. Can anyone help, I can't find any reference to it anywhere.
Posted: Wed Sep 06, 2006 12:20 pm
by s300tna
ECU warning light means something has played up gone wrong or simply had a bad momment! can be rest by dealers and they will check why it came on....
by s300tna
Posted: Wed Sep 06, 2006 12:32 pm
by david7m
Don't suppose you pressed resume on the cruise control, but in a different gear to when you set it?
Posted: Wed Sep 06, 2006 12:33 pm
by david7m
Sorry, Welcome to the site
Hope your enjoying the car too!
Posted: Wed Sep 06, 2006 12:35 pm
by S3_guy
Don't think I even have cruise control!! I guess I will have to go to Audi and get it check out. Wonder they charge to run a diagnostic onit?
Posted: Wed Sep 06, 2006 12:38 pm
by david7m
Where abouts are you? Maybe some from the site can plug there laptop in for you.
Cruise is on the left hand indicator stalk, was an option from Audi.
Got any pics/spec/colour etc.
Posted: Wed Sep 06, 2006 12:41 pm
by david7m
S3_guy wrote:Don't think I even have cruise control!! I guess I will have to go to Audi and get it check out. Wonder they charge to run a diagnostic onit?
I'd ring a few dealers first, prices can vary.
Posted: Wed Sep 06, 2006 9:51 pm
by neckarsulm
Main dealers charge about 60UKP though it varies. I have VAG COM and happy to do it FOC, I'm near J3 M42.
Just had it on my 2001 210 S3, it was a fault relating to Oxygen (Lambda) sensor heating and would come on after a few mins of driving. I'm pretty sure it was relating to my lazy thermostat not allowing engine to warm up.
Does your coolant gauge get to 90 degrees (vertical) and stay there or does it move around once engine warmed up?
Could be something else like an air leak or a misfire caused by a dreaded coil pack.
Is it under warranty?
Posted: Thu Sep 07, 2006 6:38 pm
by S3_guy
Mate with Vagcom checked it and it threw up this code :
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00
The cam belt was changed just before I bought it but by a VAG specialist, not Audi themselves. Is it likely to be just out a tooth? Just a matter of getting the timing redone?
Posted: Thu Sep 07, 2006 11:03 pm
by neckarsulm
Sounds likely as belt was just changed.
There could be a fault with either sensor which could cause this but always check what has recently been disturbed first i.e. the belt!
