MAF & LAMDA SENSORS
Posted: Mon Jul 24, 2006 10:42 pm
It's official!!! My engine melted because the MAF sensor was giving spurious readings and the lamda (02) sensor had failed. This meant the ECU didn't have a clue what was going on in the engine so ran a lean mix that caused the overheating to eventual failure starting with a piston ring.
So I'm thinking if you haven't recently or ever.... you should get your MAF readings checked and your lamda sensor.
It's a small price to pay compared with a rebuild.
MAF sensor is 75 plus vat and the lamda 95 plus vat so not a major expense really.
Even with both sensors failing and checking with my VAG-com software the car showed no faults prior to meltdown or after!!!!!!!
Also Audi had it twice and didn't check these when investigating prior to meltdown.......
