Horrific noise in fifth gear!!
Posted: Tue Oct 18, 2005 2:41 pm
by deansmith
I was driving home the other day accelerating to around 70mph i put it into 5 fifth. As soon as i changed the car started jumping around and making horrible noises (tractor like), i thought it was going to stall so i took it out of fifth and into sixth....where it was fine! I can't make it do it again (i'm taking this as a good thing), but i'm worried if it does the car's goona blow! Does anyone have any ideas at all? I have searched through the forum but can't find anything! Is there anyone in hants/guildford area that has vag com that i can plug in and check for faults? :D Revo on sat :D
RE: Horrific noise in fifth gear!!
Posted: Tue Oct 18, 2005 4:07 pm
by DuncS3
coil pack issue?
Posted: Tue Oct 18, 2005 5:56 pm
by sitas3
Dean I would love to help you out Vag-com wise but unfortunately I'm really busy at the moment.
If you're being Revo'd then they should scan the ECU for fault codes etc - ask if they don't anyway.
Re: RE: Horrific noise in fifth gear!!
Posted: Tue Oct 18, 2005 6:03 pm
by deansmith
DuncS3 wrote:coil pack issue?
From what i can see from the various coil pack threads , the car will run like a tractor from start up? is this true/ am i making it up??
SitaS3 - thanks, don't worry about it, I'll get 'em to check it out!
Thanks for your help!
