Page 1 of 2
wheel spacers
Posted: Tue Dec 30, 2003 8:58 pm
by chris22
Has anyone fiited spacers to there S3?
Where do I get them from, what sizes and how much????
Is it worth doing the mod, Im running std brakes.
Bass [img]images/graemlins/s3addict.gif[/img]
Re: wheel spacers
Posted: Tue Dec 30, 2003 9:20 pm
by Paul-RS
1.Yes
2.AmD or Forge is the usuall
3.I got 10mm front 15mm rear and new lockers. approx £160 (AmD)
some go for 10mm /10mm so the bolts are all same length
4.I needed them for the Porkers, and wanted to bring out the rear to match. A worth while cosmetic improvement, as it fully fills out the arches. Increases track width slightly too.
Re: wheel spacers
Posted: Tue Dec 30, 2003 10:20 pm
by TarmacTerrorist
Both of my front spacers have collapsed (locating stub sheared off) thought the wheels needed balancing until I found the spacers in two bits and wheels floating around on what was left of the spacer. Won't be bothering putting anymore on the car again [img]images/graemlins/033102bad_1_prv.gif[/img]
Re: wheel spacers
Posted: Tue Dec 30, 2003 10:38 pm
by chris22
Mmmm intresting. I thought RS4 came standard with spacers, or is it the style of the alloys.
Cheers Paul Ive heard of fitting spacers to clear different porkers but ive also heard a lot of probs, don't think im gonna bother [img]images/graemlins/boots.gif[/img]
Re: wheel spacers
Posted: Tue Dec 30, 2003 11:09 pm
by Paul-RS
first time ive heard of a problem. there are alot of us with porker brakes that have no choice but use them.
Re: wheel spacers
Posted: Tue Dec 30, 2003 11:29 pm
by sitas3
Paul, IIRC we only have to use the spacers with our brakes because of the design of the RSTT wheels. I'm sure that the 17" Avus is OK with this.
[img]images/graemlins/beerchug.gif[/img]
Re: wheel spacers
Posted: Tue Dec 30, 2003 11:50 pm
by Paul-RS
correct. Avus 17" you dont need spacers.
RSTT 18" you do, because of the shape of the back of the spokes.
Re: wheel spacers
Posted: Tue Dec 30, 2003 11:55 pm
by chris22
Ive heard of probs on the rs4's before and s4's but not s3's.
Im running 18" RST's.... sod it I'll go with your advice.
Does it handler any better?
Re: wheel spacers
Posted: Wed Dec 31, 2003 12:05 am
by Paul-RS
Looks so much better [img]images/graemlins/laugh.gif[/img] especially the rear. Gives it a more aggressive stance.
personal choice on if you go 10mm/10mm or 10mm/15mm like me.
the latter does mean you have two lengths of bolts
Handling, well ive had 2 S3's now. both with/without spacers/Porkers and the latest one with Quattro GmBh lowered suspension, and it certaintly hasnt had a negative effect on handling. I think its made it more surefooted.
Re: wheel spacers
Posted: Wed Dec 31, 2003 12:18 am
by chris22
That's good cos Im running 18" RST's and Gmbh lowered.
I was a bit concerned about the wheels catching the arches.
My previously S3 had 17" avis and std suspension and seemed to handle better! or is it just me [img]images/graemlins/confused.gif[/img]
Re: wheel spacers
Posted: Wed Dec 31, 2003 12:31 am
by Paul-RS
you can scuff the front inner arch liner on particularly rough roads, when making good progress [img]images/graemlins/wink.gif[/img] [img]images/graemlins/sekret.gif[/img]
But mines been fine since i brought the tire pressures back up to 36psi instead of the 33psi they were on.
Re: wheel spacers
Posted: Wed Dec 31, 2003 9:16 am
by DuncS3
I have run 10mm spacers for a long while now with no problems. Agree with Paul, the car looks so much better with spacers on and I would recommend them 100%. No negative effects on handling either (and no rubbing either on 36 psi) running 18" RSTTs with lowered suspension.
Dunc [img]images/graemlins/s3addict.gif[/img]
Re: wheel spacers
Posted: Mon Jan 05, 2004 4:25 pm
by Domcj
Sorry to be a pain but I am a newbie to the S3 after driving VW's for years and here mentions of GmBH ?? What is this I know its for suspension but what ?
Re: wheel spacers
Posted: Mon Jan 05, 2004 5:03 pm
by Paul-RS
GmbH is equvalent to our Limited, after a company name
Gesellschaft mit begrenzter Haftung - a limited company
Its simply refered as Quattro GmbH suspension (optional lowered 20mm, uprated and stiffened upgrade) to avoid confusion against the standard fitted suspension to quattros...
Re: wheel spacers
Posted: Wed Jan 07, 2004 2:53 pm
by S3MUD
So this is the standard suspension for s3's?
