S3 OEM Brake Pads
Posted: Mon Nov 03, 2003 11:05 pm
by Riz_RS4
Is there a visual way of checking how much grip i have left on my pads..... the block itself has about 1.5cm thinkness.... does it wear all the way down or am i near to replacement time?
Riz [img]images/graemlins/29428-red4.gif[/img]
Re: S3 OEM Brake Pads
Posted: Tue Nov 04, 2003 12:01 am
by Hopsta
Theres 2 wires that are embedded into the pad, once this has been worn through you'll get an error come up on the DIS. Then its pad change time.
Posted: Tue Nov 04, 2003 7:11 pm
by Riz_RS4
Any idea what thickness these sensors are embedded into the pads? just trying to work out how many miles ive got left on my pads?
Riz [img]images/graemlins/beerchug.gif[/img]
Posted: Wed Nov 05, 2003 1:42 am
by Mo_S3
When ulook at the pad u can see the bit that does the braking and the and the metal that it is bonded to which is obviously a bit bigger. If ur pad is getting pretty near to the metal plate then expect ur brake warning lite to come on at anytime. Even with the brake light on u still have some life left in the pads so its not 'oh [censored] ive got no brakes' time just yet.
Do u follow that Riz ?
Posted: Wed Nov 05, 2003 9:50 am
by Riz_RS4
Yup got it ... yippe looks like ive got around 1.2-1.5cm of pads left still.... quality
Riz [img]images/graemlins/s3addict.gif[/img]
Posted: Thu Nov 13, 2003 8:43 am
by Hopsta
You prepping up for the 2nd then Riz, your going to need more than that to get past Fatcat [img]images/graemlins/tongue.gif[/img]
Posted: Thu Nov 13, 2003 7:36 pm
by Riz_RS4
Just making sure ive got enough pads left and to work out when i will need to have them changed [img]images/graemlins/wink.gif[/img]
p.s. there is no 2nd place.....
Posted: Fri Nov 14, 2003 12:14 am
by wazza
but there is a last place..... [img]images/graemlins/<beep>_you.gif[/img]
