Indicators have just packed up on 2001 S3. Bulbs and fuses are okay, indicators either don't work at all or start to flash then stop - this happens on left/right side.
Thinking this is the relay. Anybody else come across this? If so, is this an easy-ish fix as don't want to take to stealers.
Read on other Audi sites that relay is behind/built into hazard switch but not sure on A3/S3.
Thanks in advance!
Indicator fault...relay?
RE: Indicator fault...relay?
this is a common fault on A3/S3/A6/A2/TT models and does require a new relay which is the hazard light switch itelf,easy job pull off the trim around the hazard switch,remove switch fit new job done.
Yes, mine went a couple of years ago, about £35 IRC.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
Thanks guys. Got relay from dealers. Managed to remove facia trim with improvised hacksaw blade! No damage to trim
Users browsing this forum: No registered users and 8 guests
