Coolant Temperature Warning light
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
mgkd
Post by mgkd » Thu Jan 25, 2007 1:16 pm
Can anyone, help?
I have a problem; whenever the temperature is below 5c (ie most of the time in the mornings at the mo.) my Coolant temp warning light is flashing. It continues for about 1 min then disappears and the display reverts to normal.
I mentioned this to the Audi dealership last time I was in there and they couldn't find any record of the problem on the onboard computer. They told me to monitor it and let them know... not very helpful.
Has anyone had this before and what was the resolution?
DuncS3
RE: Coolant Temperature Warning light
Post by DuncS3 » Fri Jan 26, 2007 12:04 pm
You should find that its a known issue - it showed up once on my car about 2 years ago and the dealer swapped the coolant bottle under warranty
Dunc
mgkd
Post by mgkd » Fri Jan 26, 2007 8:33 pm
Thanks very much, I'll check that one out.
Fingers crossed it will work out!
Miles
tominski
Post by tominski » Wed Feb 07, 2007 5:05 pm
Have you fixed this. Mine is doing this to!>... So annoying.
mgkd
Post by mgkd » Wed Feb 21, 2007 1:01 pm
Just to let you know this was fully rectified by replacing the 'coolant pressure bottle' the part was only £10 inc VAT! :beerchug:
Thanks Dunc!
NB That beep is the most annoying noise early in the am.
BlackS3
Post by BlackS3 » Fri Feb 23, 2007 10:28 pm
Yeah I had that problem too. Nice it was a cheap fix with new bottle
Return to “S3 (Typ 8L) 1999-2003”
