Does your S3 fuel pump prime when you open the door?
Hi,
Got problem with mine bad starting when left overnight, takes a lot of cranking before it catches and then it splutters unless I pause for a few secs from turning key to cranking after which it starts perfectly.
A mechanic asked me to check if I can hear the fuel pump prime on opening the door but it definitely doesn't. (Tried it on a V6 4mo and it does).
Obviously S3 is different car so I appeal to all you fellow forum members, can you tell me if yours does?
Ideally I'd like to know from someone who has left their car overnight or over say 12 hours as this would be when mine plays up.
Many thanks.
Many thanks.
RE: Does your S3 fuel pump prime when you open the door?
When I go to my car in the morning, I check that it is in neutral standing outside, turn the key to prime the pump, then start the car. I then put my bag in behind the seat, get in and go
You can definately hear the pump, but not sure if it does this all the time or just when left overnight, because I only do that procedure first thing.
Dave
Dave
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
Thanks Dave.
But do you hear the fuel pump prime on opening the drivers door?
[you can tell me tomorrow after it's been left overnight if you like just to be sure!]
Re: RE: Does your S3 fuel pump prime when you open the door?
Don't quite followneckarsulm wrote:Thanks Dave.
Dave
RE: Re: RE: Does your S3 fuel pump prime when you open the d
Nothing to do with turning the ignition key.
Go to car, unlock with remote, go for door handle with your hand, as door opens, can you hear the fuel pump prime?
Some later VAG cars are designed to prime the fuel pump when the drivers door opens.
Thanks for your help so far
Just checked my 02 car and I didnt hear a fuel pump on door opening
Dunc
Dunc
HHHHHHhhhhhhhhhhmmmm, that sounds a bit dangerous to me. How about if you keep opening and closing the door to clean it and put things in the back ...... is it going to keep priming every time ?!?!?!?!?
Dave
Dave
Nope, there appears to be a time delay.
Checked a Golf 1.8T (2002) and it does it!
BUMP!
Any S3 owner - do you here the fuel pump 'buzz' for 2 seconds when the drivers door is opened after car has been left for a few hours?
You can also here the buzz if you turn the ignition key but pause before you crank the engine.
PLEASE SOMEONE TELL ME THIS SIMPLE THING!
Users browsing this forum: No registered users and 36 guests
