What does this dash light mean?
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
S3_guy
Post by S3_guy » Wed Sep 06, 2006 9:50 am
I've just bought a 225bhp S3 and this dash light has just appaered. Car appears to be driving fine with no loss in power or strange noises. It stays on constantly. Can anyone help, I can't find any reference to it anywhere.
s300tna
Post by s300tna » Wed Sep 06, 2006 12:20 pm
ECU warning light means something has played up gone wrong or simply had a bad momment! can be rest by dealers and they will check why it came on....
s300tna
david7m
Post by david7m » Wed Sep 06, 2006 12:32 pm
Don't suppose you pressed resume on the cruise control, but in a different gear to when you set it?
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
david7m
Post by david7m » Wed Sep 06, 2006 12:33 pm
Sorry, Welcome to the site :thumbs: Hope your enjoying the car too!
S3_guy
Post by S3_guy » Wed Sep 06, 2006 12:35 pm
Don't think I even have cruise control!! I guess I will have to go to Audi and get it check out. Wonder they charge to run a diagnostic onit?
david7m
Post by david7m » Wed Sep 06, 2006 12:38 pm
Where abouts are you? Maybe some from the site can plug there laptop in for you.
Cruise is on the left hand indicator stalk, was an option from Audi.
Got any pics/spec/colour etc.
david7m
Post by david7m » Wed Sep 06, 2006 12:41 pm
S3_guy wrote:Don't think I even have cruise control!! I guess I will have to go to Audi and get it check out. Wonder they charge to run a diagnostic onit?
I'd ring a few dealers first, prices can vary.
neckarsulm
Post by neckarsulm » Wed Sep 06, 2006 9:51 pm
Main dealers charge about 60UKP though it varies. I have VAG COM and happy to do it FOC, I'm near J3 M42.
Just had it on my 2001 210 S3, it was a fault relating to Oxygen (Lambda) sensor heating and would come on after a few mins of driving. I'm pretty sure it was relating to my lazy thermostat not allowing engine to warm up.
Does your coolant gauge get to 90 degrees (vertical) and stay there or does it move around once engine warmed up?
Could be something else like an air leak or a misfire caused by a dreaded coil pack.
Is it under warranty?
S3_guy
Post by S3_guy » Thu Sep 07, 2006 6:38 pm
Mate with Vagcom checked it and it threw up this code :
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00
The cam belt was changed just before I bought it but by a VAG specialist, not Audi themselves. Is it likely to be just out a tooth? Just a matter of getting the timing redone?
neckarsulm
Post by neckarsulm » Thu Sep 07, 2006 11:03 pm
Sounds likely as belt was just changed.
There could be a fault with either sensor which could cause this but always check what has recently been disturbed first i.e. the belt!
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 58 guests
