Just recently bought a 2001 S3 (and love it!). Problem is the car has an intermittent 'grinding/rubbing' noise coming from the front tyres when on full lock at parking speeds.
Sounds like the tyre is catching on the arch - checked this out and no issues (car is also running standard 17" Avus' and suspension setup).
This only happens very so often and is hard to repeat when it does!
Any thoughts??
Grinding noise on turning - what is it??
RE: Grinding noise on turning - what is it??
My mistake. Problem seems to be coming from rear of car. Sounds like handnrake may be sticking and causing rubbing noise - is this common? Noise seems to go after setting off, so thing it could be rear discs/pads binding. Make a noise lilike the the tyres aren't turning when it happens!
I had a similar problem on my S4..turns out to be that where I parked the car the tarmac was quite loose and it was simply the tarmac/stones being ground under the front tyres. The problem stopped when I paked the car in the garage. Hope your problem is as simple as that one!
Huge Grin
If you dont "do it now" you never will.
Huge Grin
After I have washed my car or heavy rain, when I first drive off after leaving it over night, the pads are stuck to the disc and it makes a grinding noise for a few metres, plus the brakes are sensitive. This is normal.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
Users browsing this forum: No registered users and 93 guests
