today i revo'd my audi S3
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
kriszty
Post by kriszty » Mon Apr 07, 2003 8:23 pm
Well today was the day that my local dealer here in Holland reprogrammed my ECU with the Revo program.
I was very nervous cause it was the first car to be revo'd by him, even me i could not sleep last night, i thought what should happen if windows crashed when it was in program mode, should i ever start my car again ?
Well everything went ok, and within 15 min. everything was ready, so i went for a short test drive .
already at first gear i could notice that my car was willing to pull very hard, so after a short warmup i decided to give more gas, and yes there is a big amount of torgue and power, my first reaction was WOW !!!.
i think the most gain is between 1500-4500 rpm
after my short test i went back to my dealer and we changed also the standard Valve with an Bonalume Valve.
well back again for testing, the first thing i noticed is after putting the turbo alive and releasing the gas the valve give a nice sound ( like pffffffffffffff ) even in the short time i drove my S3 with the new valve i thought that it was more faster than with the standard vale !!
Althoug it is my first day with the revo code, all i can say is that i will have a good sleep tonight.
setting is Low-Boost 9 ( standard revo setting i assume )
greetings from holland
kriszty
Riz_RS4
Re: today i revo'd my audi S3
Post by Riz_RS4 » Mon Apr 07, 2003 8:27 pm
Enjoy, are you running shell optimax? should make a big difference! [img]images/graemlins/thumbs.gif[/img]
Image I`m just a hardcore petrol head :)
Bushy
Post by Bushy » Mon Apr 07, 2003 8:32 pm
kriszty welcome here and congratulations on your tuning
i hope you are very happy with it.
Can you get 98RON fuel there?
Can't beat a bit of boost!
kriszty
Post by kriszty » Mon Apr 07, 2003 8:39 pm
Hi guys,
thxs for all the replies, yep here in holland i can choose between 95 or 98 octan ( i think in england that is optimax ? ) i always use the 98 octan fuel, even before i get chipped. [img]images/graemlins/smile.gif[/img]
Riz_RS4
Post by Riz_RS4 » Mon Apr 07, 2003 8:44 pm
So do you plan any other mods?
kriszty
Post by kriszty » Mon Apr 07, 2003 9:03 pm
the car is already lowered with sport springs by H+R, the only mod what i want to do more is replacing the front brake disc with an original audi disc and drilled it, together with the brembo calipers and pads.
kriszty
Riz_RS4
Post by Riz_RS4 » Mon Apr 07, 2003 9:06 pm
Cool, welcome and feel free to ask questions! [img]images/graemlins/s3addict.gif[/img] [img]images/graemlins/thumbs.gif[/img]
Bushy
Post by Bushy » Mon Apr 07, 2003 9:15 pm
nice idea, brembo brakes on audi callipers, has anyone else tried this?
kriszty
Post by kriszty » Mon Apr 07, 2003 9:32 pm
i thought the seat cupra R has a simular brake system, my local dealer said that the original disc from the audi S3 are very good, he uses these discs and drill holes in it , than use the brembo calipers and pads, it's much cheaper than a complete brembo brake-set.
greetings, kriszty
sitas3
Post by sitas3 » Mon Apr 07, 2003 11:32 pm
Kriszty, I have a new brembo caliper/disc set up on my car for £650 which uses 324x28mm discs - however I wasn't aware that there was a brembo caliper set to fit with the standard S3/TT disc size (312mmX24 iirc) - maybe these brembo calipers your dealer wants to use are from the ibiza cupra R which uses a smaller disc/caliper? [img]images/graemlins/confused.gif[/img]
kriszty
Post by kriszty » Tue Apr 08, 2003 6:41 am
hi sita,
does this mean it is not good ? what i have to look for ?
txs, kriszty
s6plus
Post by s6plus » Tue Apr 08, 2003 8:04 am
hello kriszty,
good to see some people from holland over here.
I´,ve a question...does your garage drill those dicss themselves??
Other thing....is there a audi s club or so in Holland???
greetings [img]images/graemlins/greyrs4.gif[/img]
David
sitas3
Post by sitas3 » Tue Apr 08, 2003 9:09 am
Hi kriszty,
due to the weight of your car (mine is 1460kg), the smaller caliper/discs from the Ibiza Cupra R may not be up to the job - as a minimum, you need to be using standard size S3 discs, or upgrade to the Brembo caliper from the Leon Cupra R which uses the larger 324x28mm discs or even consider the bigger Porsche/Movit upgrade route which are considered to be the best by many people on here.
However, after having a good discussion with someone last night, brake longevity seems to be affected by the way people drive their cars and brake application style, as well as allowing the discs/pads to warm up and cool down sufficiently.
simonelman
Post by simonelman » Tue Apr 08, 2003 10:50 am
So your new set up wont last long
[img]images/graemlins/jump.gif[/img]
SimonS3MTM
sitas3
Post by sitas3 » Tue Apr 08, 2003 12:23 pm
SimonS3MTM
probably not hehe.. [img]images/graemlins/biggrin3.gif[/img]
[img]images/graemlins/033102ass_1_prv.gif[/img]
Return to “S3 (Typ 8L) 1999-2003”
