DIS: Faulty Dynamic Headlight Range - Help needed
Posted: Thu Mar 31, 2011 4:06 pm
Hello all
So, my headlight levelling seems to be faulty - I have run a scan from a copy of Vagcom i have and it has no error codes that I can see.
The lights do not move at all when the are turned on, so someone suggested it may be the sensor on the rear axle?? Anyone know where this is and what it looks like? Pics maybe? Help would be appreciated..
VAG-COM Version: Release 409.1-S
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 910 560
Component: 4.2L V8/5V G 0030
Coding: 0011711
Shop #: WSC 63351
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 517 Q
Component: ABS/ESP allrad 3032
Coding: 04595
Shop #: WSC 06435
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 08: Auto HVAC
Controller: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
No Faults Found
Address 09: Cent. Elect.
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0416
Coding: 01011
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 N
Component: Lenks·ulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17: Instruments
Controller: 8E0 920 980 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01400
Shop #: WSC 00658
WAUZZZ8E43A358411 AUZ6Z0C0013296
No Faults Found
Address 45: Inter. Monitor
Controller:
Note: Excessive Comm Errors
Address 46: Central Conv.
Controller: 8E0 959 433 BC
Component: Komfortger·t TBF 1712
Coding: 06859
Shop #: WSC 00726
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
No Faults Found
Address 56: Radio
Controller: 8E0 035 195 P
Component: symphony II NP2 0152
Coding: 01200
Shop #: WSC 00636
No Faults Found
Address 76: Park Assist
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00104
Shop #: WSC 63351
No Faults Found
End --------------------------------------------------------------------------------------------------
I am assuming 55 is the module? Xenon range? No faults found??? Weird... Comments?
Address 01: Engine
Coding: 0011711
Shop #: WSC 63351
Coding: 04595
Shop #: WSC 06435
No Faults Found
Coding: 00000
Shop #: WSC 63351
No Faults Found
Coding: 01011
Shop #: WSC 63351
Coding: 00041
Shop #: WSC 63351
Coding: 01400
Shop #: WSC 00658
No Faults Found
Controller:
Coding: 06859
Shop #: WSC 00726
1 Fault Found:
35-00 - -
Coding: 00060
Shop #: WSC 63351
No Faults Found
Address 56: Radio
Coding: 01200
Shop #: WSC 00636
No Faults Found
Coding: 00104
Shop #: WSC 63351
No Faults Found
