Coolant Temp sender. Easy fix?
Posted: Fri Dec 11, 2009 6:28 pm
Hello.
My friend's temperature guage is playing up on his B6 S4. Vagcom says:
Has anyone done this and can give me some pointers?
CheeRS!
Since he'd struggle to change a wheel, I'll probably end up fixing this.Friday,11,December,2009,16:43:15:19387
VCDS Version: Release 908.1
Address 01: Engine Labels: 079-910-560-BBK.lbl
Control Module Part Number: 8E0 910 560 HW: 8E0 907 560
Component and/or Version: 4.2L V8/5V G 0040
Software Coding: 0011711
Work Shop Code:
1 Fault Found:
19497 - Powertrain Databus: Implausible Engine Temp. Message from Inst. Panel
P3041 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Friday,11,December,2009,16:44:13:19387
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Control Module Part Number: 8E0 920 931 AX
Component and/or Version: KOMBI+WEGFAHRS. RB8 D42
Software Coding: 01000
Work Shop Code: Additional Info: 1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
CheeRS!
