coil pack problem?
coil pack problem?
Post by chunky79 » Wed Aug 19, 2009 8:29 pm
My car has developped a missfire and the engine light has come on. From having a quick look through this site i ordered a coil pack from audi. Is there any way of finding out which pack is at fault without vag-com?. I know i can just do the plug and play trick but there's 8 of them and the electrical connections are bloody tight.
Dunc
no_RS
Post by no_RS » Wed Aug 19, 2009 8:32 pm
Would it showup on Vag-Com?
Post by chunky79 » Wed Aug 19, 2009 8:36 pm
I have no idea. never used vag-com but thought it should come up?
Dunc
ShaneyB
Post by ShaneyB » Thu Aug 20, 2009 11:21 am
Yeah i think it would show. Just had one of mine replaced. £70.00 all in I think.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Post by chunky79 » Thu Aug 20, 2009 4:20 pm
Thankfully my mates girlfriend works at audi at got mine for £26. It's going to be a real arse ache trying all of them but it looks like the only option. Anyone know if the engine management light will go out on it's own when i have changed the coil??
Dunc
Pete.S
Post by Pete.S » Thu Aug 20, 2009 8:42 pm
Yes it will show on vag-com and yes the light will go out, as long as it's the coil causing the problem!
Post by chunky79 » Thu Aug 20, 2009 8:59 pm
i have gone through all the packs with a new one test and then replacing. it seemed to sort the misfire for 10 mins or so but then it came back again. The light stayed on all the time. I now have the Air bag and esp light on after removing the air box . The car will start but runs like a bag of <beep>.
Pete.S
Post by Pete.S » Thu Aug 20, 2009 10:34 pm
Faulty lambda sensor/problem with cats?
Post by chunky79 » Fri Aug 21, 2009 6:31 am
I really have no idea. I have posted for some help from someone with vag-com in the vag-com section but had no reply yet. :cry:
BlingBling
Post by BlingBling » Fri Aug 21, 2009 8:46 am
Its times like this that makes a small £10 investment in a fleabay cable worthwhile. The soft-ware is free from the Rosstech site. It will allow you to scan and clear faults. Also the Rosstech database will allow you to interpret the codes and diagnose the problem for yourself. If you want more functionality you can firstly buy a license, $99, for the shareware. This opens up more features of the shareware software. If you then want even more functionality that is offered from the latest software/cable then the license fee is subtracted from the price. If you go the whole hog then it will have only cost £10.
Post by chunky79 » Fri Aug 21, 2009 4:40 pm
I ahve been talking to a guy from audi and he say'a they change all coils now even if one has failed due the them being sensitive. The other problem has come up cause i un plugged the maf. Got to go and pick the 7 new coils tomorrow but still need the codes wiping.
Dunc
elmo
Post by elmo » Fri Aug 21, 2009 4:48 pm
Dunc,
Glad to hear it's almost sorted (Albeit £240 later!)
Just wanted to say that I went onto fleabay to source a cable for myself and saw that a new CAN type cable connector came in 2003-4. Not sure the £10 fleabay cable would do for the S4, you may need the more expensive £35 CAN compatible cable.
I am sure that someone from this site will know exactly which type cable is required for the S4 and be able to tell me before I make the mistake myself!
BlingBling
Post by BlingBling » Fri Aug 21, 2009 8:30 pm
elmo wrote:Dunc,
I have a 2003 S4 and bought a USB OBD2 KKL Interface. I believe that his will also do certain B7's or the basics on a B7. This thread is really helpful. http://www.audizine.com/forum/showthread.php?t=158766
Post by chunky79 » Sun Aug 23, 2009 9:56 am
Update. I have now changed all 8 coil packs and the car seem's to be running ok. Still have the warning lights on the dash cause i've not had any luck with someone coming and resetting the fault codes.
BlingBling - can you re set codes with the cable you have? also, what other functions does the lead/software give?
Dunc
h8cak
Post by h8cak » Sun Aug 23, 2009 10:04 am
Just answered you on srs. Get back over there :thumb:
Wide Body S4
Users browsing this forum: No registered users and 74 guests
