What is RARB ?
Posted: Fri May 01, 2009 9:33 pm
by Ridgeway
I'm a newbie, I can ask stupid questions (i hope)
RE: What is RARB ?
Posted: Fri May 01, 2009 10:10 pm
by Scotty
Rear Anti Roll Bar
Put the RS4 one on. It's worth it ;)
Posted: Fri May 01, 2009 10:17 pm
by Ridgeway
Thanks Scotty,
Do you have a part No ? Price etc ?
Usualy ARB's are easy to fit, is this one ?
Sorry for so many questions
Posted: Sat May 02, 2009 9:53 am
by Scotty
I can't recall. I think about £80 including the new rubbers (due to wider diameter). I then paid the local exhaust centre £30 to fit it.
The key when fitting is that you keep the weight on the wheels. i.e. don't have the wheels hanging due to using a post lift etc.
I went to the exhaust place as I could drive it on to a ramp and raise the car. If means when the ARB is fitted it avoids twisting up the rubbers which happens if you raise the wheels.
It's a simple job although my Milltek made it a little more difficult so they have to loosen a clamp or two to get the extra few mm of space needed.
p.s. You shouldn't need to worry about part numbers. Just tell the dealer you want an RS4 ARB along with the rubbers etc.
Posted: Sat May 02, 2009 10:27 am
by Blue_Thunder
You should consider even better ARBs such as the Hotchkis or H&R kits. More pricey, but stiffer than the stock items.
