My S4 very ill
Posted: Mon Sep 29, 2008 8:48 pm
by Gordobeer
Hi new to all Audi, has Audi S4 Avant from march 2008, all was fine until now, very bad vibrations coming from drive, took to Garage to check, was told that cv joint had gone on prop shaft, changed cv joint, now the car is making more of the same sort of noise as before, the sort of clicking you get when you turning, but not turning, when you set fast and hard the vibration is very very bad, if you set off fast when turning, you get the normal light on the dash,for the track control, but you also get brake light flashing/beeping to, then ok again, the dash not the vibrations.
Anyone help please
Posted: Tue Sep 30, 2008 6:46 am
by chunky79
Possible wheel bearing?
Posted: Tue Sep 30, 2008 9:32 pm
by Mockenrue
Hi Gordobeer
Yes, I agree with chunky79 - this sounds very much like the same symptoms I had a few weeks ago, and that did indeed turn out to be a knackered wheel bearing. Here's my thread:
http://www.rs246.com/index.php?name=PNp ... ic&t=71977
Good luck :)
Posted: Tue Sep 30, 2008 11:41 pm
by Gordobeer
Thanks, will have to check this out.
Posted: Tue Oct 07, 2008 2:57 pm
by Mockenrue
How many miles has it done?
Posted: Thu Oct 16, 2008 10:15 am
by Gordobeer
All sorted now, was the cv joint on the end of the prop shaft, and no i didn't get from Audi full prop with cv joints, just the cv joint from prop shaft clinic in Bradford cost of £135
Posted: Thu Oct 16, 2008 8:26 pm
by chunky79
I thought you had already changed your cv joint??
Dunc
