Page 1 of 2
S4 upgrades?
Posted: Fri Sep 19, 2008 12:15 am
by mmammel10
I have a 2005 S4 and i was wondering what upgrades i can get on it. right now it is completely stock with the tiptronic transmission.
RE: S4 upgrades?
Posted: Fri Sep 19, 2008 8:29 am
by BlingBling
Performance I assume.
RS4 Rear anti-roll bar
Remap
Custom exhaust system with sports-cats.
Custom exhaust manifold
Lighter alloys
That’s about your lot really. The stock brakes are more than good enough for the job. The biggest benefit of changing them would be the reduction in unsprung weight.
RE: S4 upgrades?
Posted: Sat Jan 10, 2009 1:04 am
by p1tse
i was up at APS once and at the time, some guy was getting his ARBs changed, not sure what to but might be the rs4 item as mentioned above to improve handling
Posted: Fri Jan 16, 2009 12:34 pm
by Mockenrue
Was it silver? If so then that was me! I remember you there with your TT.
I had the RS4 DRC rear ARB installed and it's definitely a worthwhile mod for any B6/7 S4, especially for the money. It tightens up the handling and reduces understeer considerably.
Re: RE: S4 upgrades?
Posted: Fri Jan 16, 2009 1:13 pm
by chillo
BlingBling wrote: Custom exhaust system with sports-cats.
Do you mean one off custom made?
Is the Milltek full system include the manifold?
Posted: Fri Jan 16, 2009 2:09 pm
by P_G
Nope, manifolds are separate. Milltek only do sports cats, down pipes and cat backs.
Depends on your budget regarding mods but the most common hev already been listed but could also include new brakes front and rear. S4 brakes are good, but if you go for full exhaust / manifolds and a remap believe me you'll need them upgraded. Cheapest is the B7 RS4 front brake upgrade through to most expensive which is the Movit system for front and rear. Marginal brake improvement would be to change your brake lines to braided hoses and DOT 5.1 fluid.
If money is not an option then a reliable supercharger kit is available for the S4 V8, you can also get a cold air intake for the engine and carbon fibre bonnet and front wings for the B6 S4 to reduce weight over the front end or use KW3 coilover suspension kit.
Posted: Fri Jan 16, 2009 4:04 pm
by BlingBling
I will be performing a mini brake upgrade soon. In that I am fitting some braided hoses, grooved and slotted discs, DOT 5.1 and Mintex pads. All the aforementioned will improve the brake performance at a palatable price.
FYI I got the discs from ECS Tuning located across the pond.
Posted: Fri Jan 16, 2009 10:58 pm
by P_G
Which ECS disks are they? Is it the ones in the stage 3 kit? I know one other person with a B6 S4 saloon who tried them as they are supposed to by up to 40% lighter than OEM disks but he had huge problems with them, 3 replacement sets from ECS after warping before binning the concept and going braided hoses and EBC pads.
Posted: Sat Jan 17, 2009 1:11 pm
by BlingBling
Not the ones that scoTTy had fitted. These are zinc plated, slotted and drilled steel discs.
Posted: Sat Jan 17, 2009 8:25 pm
by P_G
So they ahve changed the design and construction of them then, good to hear.
Posted: Sat Jan 17, 2009 9:54 pm
by p1tse
Mockenrue wrote:Was it silver? If so then that was me! I remember you there with your TT.
crickey small world!!!
hope all is well, that s looked ace, and having had the TT for a couple of years, looking what the future holds on a motoring front ;-)
i do take not of what enthusiasts say, and that was almost 2 years ago!
Posted: Sun Jan 18, 2009 10:15 am
by BlingBling
P_G wrote:So they ahve changed the design and construction of them then, good to hear.
Not sure if they have changed the design of the 2-piece discs. But they also sell OEM discs and a line of slotted and slotted/drilled discs. The are slightly lighter than the OEMs but nothing significant like 2-piece jobbies.
Posted: Thu Jan 22, 2009 11:35 pm
by frazered
those ecs discs look good vfm! how much is the shipping?
Posted: Tue Feb 17, 2009 2:04 pm
by BlingBling
frazered wrote:those ecs discs look good vfm! how much is the shipping?
I had a family memeber bring them over. Check out there website for P&P but you may also have ot factor in customs duty.
Posted: Wed Feb 18, 2009 6:29 pm
by ShaneyB
GEARBOX REMAP !!!
