Oil Change
Posted: Thu Mar 27, 2008 8:05 pm
by Spoof
The S4 is going to get used on track a bit in the next few months and has a trip to Italy in June, so a couple of oil changes will be on the cards.
I have found that after my Nurburgring trip, it has a bit of a thirst for Edge 5W30 so I have decided to change to a slightly different grade.
Shell Helix Ultra 5w40 seems to fit the VW specs fine, but has anyone had any experience with a thicker oil?
Anything different when changing the oil to a normal car? any special Audi tools?
Secondly, has anyone managed a DIY gearbox oil change on an Auto? Done plenty of searches and come up with various answers.
Thanks.
Chris.
Posted: Fri Mar 28, 2008 1:22 am
by nidfix
I am using for a while Mobil 1 0w40 without any problem.
So as long as it complies with VW503.01 spec (or even VW503.00 if you change it more often than recommended in Europe) it should be Ok.
Posted: Fri Mar 28, 2008 8:56 am
by BlingBling
I currently use Shell Helix Ultra 5w40 and have just returned to Germany from Blighty, 1400 miles, and the oil level has not budged. If your considering doing a couple of oil changes and the mileage is low then 5w-40 should be fine. I use that grade becasue I do few miles, 6000p/a, and it was recommended by Guy from Opie Oils.
The only difference to other cars is the position ofthe oil filter. its on top of the engine at the back.
