ignition problem
Posted: Tue Jan 08, 2008 3:17 pm
by s4bandit
hi guys
recently been experiencing a slight ignition problem
put the key in, turn on, wait for ok then turn again to start
and nothing happens for maybe 1 second and then the car starts
its happended maybe 10 times in 2 weeks but this morning
when i went to start, nothing happened at all, ( after the ok i mean )
so i went back to switch off, turned on , waited for ok and this time it started.
think the problems getting worse, bit worried it might not start at all next time.
any one else had and fixed this problem before ?
cheers
Posted: Tue Jan 08, 2008 7:32 pm
by Pete.S
Yep, sounds just like a failing starter motor, had exactly same symptoms
Posted: Wed Jan 09, 2008 7:52 am
by s4bandit
doesn't sound very good to me........
how long have i got ? how much will it cost ?
cheers
Posted: Wed Jan 09, 2008 8:49 am
by BlingBling
A similar scenario was happening just before my battery died but not as regular as stated above.
Posted: Wed Jan 09, 2008 7:14 pm
by Pete.S
Mine never completely failed but it got progressively worse - and it sounds like yours is pretty bad if it's not turning over at all sometimes. Cost was about £125 + VAT plus fitting.
If it doesn't turn at all again before you get it replaced, try jolting the car back & forwards as quickly as you can, it worked for me on one occasion!
Posted: Wed Jan 09, 2008 11:22 pm
by s4bandit
nice 1
cheers pete, i'll get it booked in
Posted: Fri Jan 11, 2008 8:11 am
by chunky79
Hi mate
Our car has had the same problem in the last 4 weeks. It's probably only happened once a week. Doesn't seem like a starter fault to me on mine but could be wrong. There's nothing you can do apart from wait for it to go.
Dunc
Posted: Mon Feb 18, 2008 10:34 pm
by s4bandit
its now been 2 months since the first time it happened and its still not got any worse
i would say a couple of times a week on average, seems to happen more when its really cold
i'll let you know if it gets any worse
cheers
