Page 1 of 2
Where do you connect your det can's to on your S4 ??
Posted: Wed Mar 07, 2007 10:58 pm
by NotNormal
Having checked my S4 for Det. on the recomended point by acouple of tuners - i have det sadly
I have the Revo re-flash on my car and will be contacting my tuner soon as i've been snowed unde lately.
I was wondering were anyone on here would recomend to connect the det can's ? (to see if your points coinside with mine)
RE: Where do you connect your det can
Posted: Wed Mar 07, 2007 11:40 pm
by shineydave
eh?
what's a det can?
infact what's det, never heard that phrase before
Posted: Wed Mar 07, 2007 11:53 pm
by NotNormal
Det is detonation.
Det Can's a kinda like head phones that you attach to the block and listen for det with
Detonation is basicly the ecu adding too much ignition and causing the fuel to be ignited at the wrong time thus losng power and not being right.
Posted: Thu Mar 08, 2007 8:45 am
by DavidT
Blimey, is this a wind up ?
These cars have an electronic knock sensor on each cylinder. You just plug a laptop in to the diagnostics port and run software called vag-com and you can find out anything about the engine (or the rest of the car).
The ECU will be controlling the 'knock' (if there is any) anyway. You will not hear the 'pinking'.
Who is your tuner ? and have they told you the car is suffering from 'det'.
Posted: Thu Mar 08, 2007 8:56 am
by tartan_rob
I would question any tuner that did not know this and thought it better for the untrained and unqualified to 'listen' for pinking.
Posted: Thu Mar 08, 2007 12:24 pm
by NotNormal
My tuner hasn't inspected my car yet - it was advised (apparently poorly) by 2/3 people off the american audi site.
My car holds back on occasion and you can hear (throught the det can's) thats all isn't as it should be.
Re: RE: Where do you connect your det can
Posted: Thu Mar 08, 2007 12:28 pm
by NotNormal
Aboviously my car has a faulty sensor then !
My cars booked in now as the software for my VAG-COM lead doesn't wanna work with the lead.
I shall see what the problem is
Posted: Thu Mar 08, 2007 12:31 pm
by NotNormal
Tartan_Rob wrote:I would question any tuner that did not know this and thought it better for the untrained and unqualified to 'listen' for pinking.
My tuner hasn't had the car nor have i had chance to speak with him as i've been working sadly.
It's booked in at Audi now for something else so they'll run a diagonostic check
Posted: Thu Mar 08, 2007 7:45 pm
by NotNormal
DavidT wrote:The ECU will be controlling the 'knock' (if there is any) anyway. You will not hear the 'pinking'.
Ohh look, i was right - i could hear DET.
You about sweeping statement isn't quite as correct as you'd like it to be now is it
*see attached image
You say i'm unqualified to listen for det but yet you know nothing about me.
I presume you have seen my low post count and assumed, wrongly, that i have no experiance with mapping and it's effect's both positve and negative.
It's a shame people jump in with both feet with sweeping statements before qualifying the situation
Posted: Thu Mar 08, 2007 7:49 pm
by NotNormal
DavidT wrote:Blimey, is this a wind up ?
........apparently NOT A WIND UP
RE: Re: RE: Where do you connect your det can
Posted: Thu Mar 08, 2007 8:31 pm
by MarkB
Shame I've only just seen this. I did wonder if it was going beyond the amount the knock sensors are able to <beep> the ignition.
What fuel are you running in it? It could also be the MAF making it run lean then pinking.
Were all the faults just the knock sensors?
Posted: Thu Mar 08, 2007 8:45 pm
by NotNormal
Yes, all faults were just knok sensors.
Fuel, i usually run it on Total Exellium, but i put £150 worth of Shell V-power and £50 for BP Ultimate (which i'm not a fan off) through the car - made no/little difference. On shell it was slightly better - but only slightly, on the bp it made no difference
The MAF reading's are ok, had Quatronics check them today along with everything else .
I've got the stock map in for the time being, but the Revo one will be being sorted ASAP
Posted: Thu Mar 08, 2007 8:51 pm
by DavidT
I stand by what I said above, its just that you have faults which is a shame and unusual. I hope you get them sorted quickly and cheaply.
Let us know what the problem(s) are when you know.
Posted: Thu Mar 08, 2007 8:52 pm
by MarkB
I take it the cars runs cleanly on the standard map?
Posted: Thu Mar 08, 2007 9:15 pm
by NotNormal
Yeah, it's sweet as a nut - has not got any knock
