Which oil for top up ?
Posted: Wed Jan 17, 2007 9:12 pm
by Trufit
Hi
I have recently purchased an 06 S4 Avant and would like to know which oil I should use for top ups. It only has 6500 miles and doesn't need any at the minute but after reading a few of the posts on here I thought it would be best to have some handy.
If you could also tell me where you get it from that would be a great help too - no I am not a total <beep> it's just that I get 50% off all oils if I buy them from BP.
Paul
RE: Which oil for top up ?
Posted: Wed Jan 17, 2007 10:58 pm
by philipwalker
If you are on "longlife" service intervals use the correct "longlife" oil.
If its a new car you may have a 1 ltr bottle in the boot? Unless the fitter who did the pdi nicked it and sold it on ebay??
Posted: Thu Jan 18, 2007 10:38 am
by Pete.S
Posted: Thu Jan 18, 2007 4:11 pm
by Trufit
Thanks for that
Posted: Thu Jan 18, 2007 8:20 pm
by PetrolDave
Castrol Edge 5W/30
Posted: Wed Jan 24, 2007 12:21 pm
by Mike_K
check the users handbook; it identifies the permitted oil standards for longlife service, and for fixed-interval. See also the following thread where I put the info from my B6 S4 handbook:
http://www.rs246.com/index.php?name=PNp ... w=previous
This talks about "multigrade thin-running oil VW 503 01 or VW503 00" which refers to a VAG code you should find on the small print on the back of each oil bottle in the shops; you should also be able to find it if you search for the oil specs on the company web-sites or wherever (try googling for 503 00 ??)
Only thing is; the handbook for a B6 was written some time ago and since then VAG have changed/ improved their standards. It's entirely possible that you can use the new standard oils as well (ie I would guess the new VAG standard for a B7 longlife would be OK for a B6 ?)
I did use Castrol SLX Longlife II but in my Halfords it seems to have been superseded by something else. Audi used some Shell Helix xxx at the last longlife service....., dont know what exactly
Posted: Wed Jan 24, 2007 2:44 pm
by PetrolDave
The Castrol SLX Longlife II has been renamed/replaced by Castrol Edge 5W/30 - which meets or exceeds all the latest VW specs for an AVS oil.
