REVO software
Posted: Mon Oct 09, 2006 5:12 pm
by NotNormal
Well , had it put on my car on saturday - not wanting more power tbh, but then again it's N/A so not likely to get a big power increase but it's done what i wanted and alittle more too
Wanted the jerkyness at town speeds to go , and with a tweek here and their of the throttle respince ect... it has ,
Also wanted the speed limmiter removed - which it has
As a bonus i have a slightly higher rev limmiter too , which makes for a better driving range with the gears
Also it's given it alot more pep in first gear, made it alot stronger - previously felt it was 2nd gear that pulled well , now it's both of them
RE: REVO software
Posted: Mon Oct 09, 2006 9:27 pm
by NotNormal
Does anyone else have Revo software or are we mainly AMD ???
RE: REVO software
Posted: Fri Apr 06, 2007 6:59 pm
by P_G
Another REVO convert. It has put the icing on the cake for me. WRC technologies and Mitch from REVO did the work, can't recommend them highly enough.
Re: RE: REVO software
Posted: Fri Apr 06, 2007 7:36 pm
by NotNormal
P_G wrote:Another REVO convert. It has put the icing on the cake for me. WRC technologies and Mitch from REVO did the work, can't recommend them highly enough.
Not anymore - it was causing problem with Knock, nothing wrong with the car and Revo didn't seem open minded enough to look into the map so mine is std now .
Posted: Mon Apr 09, 2007 10:29 pm
by P_G
NotNormal wrote:P_G wrote:Another REVO convert. It has put the icing on the cake for me. WRC technologies and Mitch from REVO did the work, can't recommend them highly enough.
Knock?
Also, did you get from REVO direct or a franchise? I've heard franchises giving similar stories hence why I went to REVO direct via WRC.
REVO software
Posted: Tue Apr 10, 2007 2:18 pm
by NotNormal
P_G wrote:NotNormal wrote:P_G wrote:Another REVO convert. It has put the icing on the cake for me. WRC technologies and Mitch from REVO did the work, can't recommend them highly enough.
Knock?
Knock = Detonation
I got it from Quattronic's - but it was Kev from Revo that it came from and he installed it on my car at their open day
RE: REVO software
Posted: Tue Apr 10, 2007 2:48 pm
by n4aat
I understood that REVO had remapped their B6 software recently. If this is the case it may sort the problem. That info was given to me by one of their franchises in Newport, Wales. I cannot vouch for its accuracy.
I am looking at the REVO software myself and don't relish having the same issues as you. Are you in the minority, or are you aware of others that have had this issue.
I have always found the REVO guys to be very helpful when I have used them in the past. But I guess you are always exposed to the professionalism of individual franchisees.
RE: REVO software
Posted: Tue Apr 10, 2007 7:49 pm
by Corey
This was the new software, Tom's car was the first one with the derestricted 6 gear limiter removed (REVO had never removed that before only the main speed limiter)
Tom wasn't happy with the response when they suggested there was an issue with the car rather than the software even though the car had no faults
RE: REVO software
Posted: Wed Apr 11, 2007 8:32 am
by n4aat
Got ya.
RE: REVO software
Posted: Thu Apr 19, 2007 1:45 pm
by RevoKev
Hey Guys, I believe the suggestion that there could be an issue somewhere else was down to the fact there were no issues when the car was first flashed and for the following months. Being an adjustable software both A/F ratio and timing can be altered (not to mention throttle response, but as that is only driver preferance it's not important here) to suit varying conditions, fuel quality, etc. The only thing we said we can't help with was turning off the ESP fully. Water under the bridge now as Corey has refunded the customer, which was authorised as a gesture of good will on our part as they were stuggling to find any issues.
RE: REVO software
Posted: Fri Apr 20, 2007 12:06 pm
by philipwalker
RE: REVO software
Posted: Fri Apr 20, 2007 12:20 pm
by david7m
I've APR too, not an S4 though.
Dave
