Speeds in gears
Posted: Tue May 03, 2005 6:55 pm
by B6S4John
Will someone post the speeds in gears per 1000 rpm Iv'e seen them somewhere but can't find them I think 6th is 24.9 ???????
JOHN
RE: Speeds in gears
Posted: Tue May 03, 2005 7:36 pm
by Scotty
Don't know if this helps -
Gear ratios:
1st 3.667
2nd 2.050
3rd 1.462
4th 1.133
5th 0.919
6th 0,778
Reverse 3.333
Final drive ratio 3.889
RE: Speeds in gears
Posted: Wed May 04, 2005 5:31 pm
by B6S4John
Hi Scooty, it would help if I had a degree in maths.
RE: Speeds in gears
Posted: Wed May 04, 2005 5:33 pm
by B6S4John
PS and in spelling. Sorry Scotty
RE: Speeds in gears
Posted: Wed May 04, 2005 9:03 pm
by Scotty
hehehe Don't ask me. I just copied out a pdf!!
All I know is they dyno's in the ration closest to 1:1 i.e. 5th in this case.
It also means you can go faster in reverse than in first!
RE: Speeds in gears
Posted: Thu May 19, 2005 10:41 pm
by B6S4John
Hi all I found them for anyone who's interested
1st=38
2nd=68
3rd=96
4th=123
5th=152
6th=155?
RE: Speeds in gears
Posted: Fri May 20, 2005 8:10 pm
by Scotty
Theoretical, stated somewhere or having you been banging it in to the limiter?
p.s. 6th is at least 165mph
RE: Speeds in gears
Posted: Fri May 20, 2005 10:12 pm
by B6S4John
Taken from a road test comparison with M3 so might not be right. They do a BHP per ton and the maths in that 'aint right so who knows. Yes I have hit the limiter a few times it comes in at 7500. Even my wife has hit it in 1st and 2nd. I think its 'cause the thing is so smoooooooooooooth you can't tell it's reving.
RE: Speeds in gears
Posted: Mon May 23, 2005 12:08 pm
by Merlot
Always hit the thing in 1st - hit it in 3rd a few times too!!
RE: Speeds in gears
Posted: Thu Jun 02, 2005 5:05 pm
by tartan_rob
From the gear ratios, you can work out %age turns of wheels to engine revs, work of the circumference of the wheels * tyre size and therefore theoretical max speeds and mph/1000k by doing the "simple" arithmetic....
Not that I give a <beep>, was just throwing my 2pence in.
Anyone know how much quicker or slower the B6 in std guise is compared to the B5 with a stage1 on it? No idea how quick my motor is (B5) but I change my "Y's" frequently and almost always run into the car in front without trying....
