Hi all.
Need a bit of advice. A few weeks ago whilst on business in london, the EML came on. Vancomycin diagnosed it as a faulty clutch pedal switch. Got that placed and a couple if days later, EML comes on again and this time the cam position sensor is faulty. Got that replaced and then a couple of days later, EML light on again and this time the engine speed sensor has failed. Got that replaced last week and the EML light has come on again and this time I have a fault on one of the injectors.
Am I missing something or am I just being very unlucky!
Any thoughts would be gratefully received.
Cheers. Paul
Major sensor issue
Re: Major sensor issue
im no mechanic.. but with luck like that i wouldnt bother with the lottery!
goose
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
What, or who, is Vancomycin?
Have you tried hooking it up to a genuine Vag Com cable, or taking it in to a dealer? Just thinking it could be a dodgy diagnosis.
| '04 S4 Avant (B6) | NOW SOLD
Hi All,
Just an update. Had to take my S4 into Audi at Teeside who have diagnosed a cam position sensor failure. Getting that sorted as we speak but hopefully that should resolve the problem.
They however did mention that if this did not fix the problem then it might be the valve chains and timing which is an engine out job. Is this usual? Would youn expect the timing just to go like that!!!!!
Cheers.
Cheers.
