Drive train servicing
Anyone know how often the gearbox and rear diff etc need an oil change?
- BlingBling
RE: Drive train servicing
According to the checklist is doesn't need changing at all just checking for leaks every 20k miles. I have a service checklist but cannot fathom how to attach the pdf. Everytime I try to open the file the extension is php and not pdf.
- BlingBling
- BlingBling
In both cases the oil goes into cycle of heating then cooling. An S4 is for sure less stressful than a Nissan GTR but it is a car that weight a lot and with a good amount of power. So for me at some point you cannot expect the oil to have the same quality as new.BlingBling wrote:The check list states it does not replacing at 1350,000km, just inspect for leaks. Seriously is there a need to replace the oil if the stealer are not looking to make a quick buck?
120000Km is probably conservative but as it is not an expensive operation, it is worth being a bit proactive, like you may change the motor oil more often than the expected 30000km service.
This is obviously a point of view.
