B6 dashboard lights
B6 dashboard lights
On my S3 the dials are illuminated all time. On the S4 they only come on with the headlights, is this normal?
Also, the S3 has a dial to adjust the brightness but I can't find any such thing on the S4, does it have one?
- Greengoblin
RE: B6 dashboard lights
Sounds perfectly normal to me, mine only come on with the headlights too.
Don't know about the dimmer option though...........
2004 S4 Avant
- BlingBling
Thanks. I wonder if it has 2 brightness settings, one for lights off and one for lights on? Maybe my lights off setting is set to min.BlingBling wrote:Mine are on constantly, B6. Only can tell when it is dusk or in a tunnel. The dimmer is not a dial like on the S3. Use the +/- button on the left hand side of the dashboard.
Re: B6 dashboard lights
If they are not on, it can be changed with VAG-COM for either scales, needles or both to be on all the time.marctwo wrote:On my S3 the dials are illuminated all time. On the S4 they only come on with the headlights, is this normal?
That's really helpful, thanks. Do you know how to do this in VAG-COM? Is it fairly obvious?ste4ie wrote:If they are not on, it can be changed with VAG-COM for either scales, needles or both to be on all the time.marctwo wrote:On my S3 the dials are illuminated all time. On the S4 they only come on with the headlights, is this normal?
Control Module select
17-Instruments
10-adaption
Then you need Ch 19 as shown below....
A019,0,Additional Features
A019,5,Additional Features
A019,6,?xxxx: Illumination (MY 2002 and above)
A019,7,0 = Needle and Scale only active at "Light ON"
A019,8,1 = Needle already active at "Ignition ON"
A019,9,2 = Scale already active at "Ignition ON"A019,10,3 = Scale (2nd Map) and Needle at "Ignition ON" active
A019,11,
I managed it after owning Vag-Com for a week, so im deff no expert
Cheers Steve
17-Instruments
10-adaption
A019,11,
Cheers Steve
Users browsing this forum: No registered users and 136 guests
