My S4 very ill
Gordobeer
My S4 very ill
Post by Gordobeer » Mon Sep 29, 2008 8:48 pm
Hi new to all Audi, has Audi S4 Avant from march 2008, all was fine until now, very bad vibrations coming from drive, took to Garage to check, was told that cv joint had gone on prop shaft, changed cv joint, now the car is making more of the same sort of noise as before, the sort of clicking you get when you turning, but not turning, when you set fast and hard the vibration is very very bad, if you set off fast when turning, you get the normal light on the dash,for the track control, but you also get brake light flashing/beeping to, then ok again, the dash not the vibrations.
Anyone help please
Post by chunky79 » Tue Sep 30, 2008 6:46 am
Possible wheel bearing?
Mockenrue
Post by Mockenrue » Tue Sep 30, 2008 9:32 pm
Hi Gordobeer
Yes, I agree with chunky79 - this sounds very much like the same symptoms I had a few weeks ago, and that did indeed turn out to be a knackered wheel bearing. Here's my thread:
http://www.rs246.com/index.php?name=PNp ... ic&t=71977
Good luck :)
2003 Audi S4 saloon
1998 Audi A4 1.9TDi quattro Sport saloon
Gordobeer
Post by Gordobeer » Tue Sep 30, 2008 11:41 pm
Thanks, will have to check this out.
Mockenrue
Post by Mockenrue » Tue Oct 07, 2008 2:57 pm
How many miles has it done?
2003 Audi S4 saloon
Gordobeer
Post by Gordobeer » Thu Oct 16, 2008 10:15 am
All sorted now, was the cv joint on the end of the prop shaft, and no i didn't get from Audi full prop with cv joints, just the cv joint from prop shaft clinic in Bradford cost of £135
Post by chunky79 » Thu Oct 16, 2008 8:26 pm
I thought you had already changed your cv joint??
Dunc
