ABS problem - driving me mad
Posted: Fri Nov 27, 2009 11:26 pm
2000MY S4, heap big ABS trouble.
The electronic limpet from the ABS pump has been to BBA Reman already, and declared healthy. In fact, my car has a newer part than the one that everyone else seems to have fail. All the wheel speed sensors have been checked, ditto the rings that go with 'em. The relays that feed the ABS system have been replaced. There are no fault codes hanging around.
My local Audi specialist has come to the point where they reckon it'll be either the ABS pump itself, or the control module for the ABS/ESP. So, £800ish list or £1000ish list, without knowing which one it'll be. They've spent a ton of time looking at it, and bless them, only billed me for a fraction of it, but now the car's back in my hands to decide what to do next.
So, in the hope that someone can offer suggestions, here are the symptoms (they're in a previous thread somewhere, but I can't seem to dig it out right now):-
* Unexpected ABS activation
- To start with all feels good, but you can then feel the pedal drop in distinct steps
- Then the ABS will kick in fully (lots of ABS pump noise)
- Then it'll either disengage, at which point you'll get the brake force for the amount of pedal travel you've ended up with, or it'll kick out and in one or two more times
* Commonly, after unexpected activation, I'll hear the pump going under the bonnet for a few seconds... when I'm stationary or back on the gas pulling away again
* When coasting with a fraction of throttle opening (according to my right foot), it feels like the car is tweaking the throttle ever so slightly
* Clicking relays under the dash on the driver's side
- If the headlights are on, the headlights (almost imperceptibly) flicker in time with the clicking relays
* Turning ESP off makes no difference
* Unplugging the electronic module on the pump cures it - but leaves me with the rear brake bias issue: no fun, well, dangerous, with winter on the way
Now, it's possible to drive through all this, but I look like a bizarre sort of learner, kangarooing up to traffic lights rather than away from them.
I'll call MRC in the morning and see if they've any ideas - or a spare ABS/ESP brain that can be swapped in to rule that in or out. I'm just not into the game of buying near £1000 parts that *might* fix it. Not on a car with 183,000 miles!
I'm all ears for other suggestions: what else does ABS/ESP take input from, which can be checked out? It's the time for a cunning fix, or selling the car to someone who wants a track slag with no ABS.
Sigh. It's such a nice car otherwise.
