Just bought S4, couple of minor issues!!
Posted: Wed Jul 08, 2009 2:11 pm
by PretendPorsche
Hey,
I recently bought a noggy s4, tuned up by mrc, im sure some of you guys would know it.
Anyway, i love the engine, been done really well.
However, i have two problems, firstly the gearchange, which seems to be a common one!!
I wont go into detail about that, as it in g-werks today for pss9s, so i asked them to have a look at it, when they fit them.
Second problem is the brakes!! Again seems to be a common problem, but i have something weird going on, when u brakes gently it almost feels like the pedal is pulsing, it could be warped or cracked discs, but it doesnt really feel like that.
I was reading that the abs often has problems, could this be what im feeling?
Also aside from the current brake set up, i dont feel that the brakes are really that great, so im looking at doing a porsche caliper upgrade, however i can only find people doing it with the 4 pot calipers, has anyone done it with the 6 pot calipers from the gt3??
RE: Just bought S4, couple of minor issues!!
Posted: Wed Jul 08, 2009 2:54 pm
by Nige_RS4
I think you will need 18" wheels for the 6-pots (the cayenne brakes are a reasonably straight forward fit onto B5 RS4 discs)
The other option (also needing 18's) is the full RS6 (or B7 RS4 brakes).
Re: RE: Just bought S4, couple of minor issues!!
Posted: Wed Jul 08, 2009 3:11 pm
by PretendPorsche
Nige_RS4 wrote:I think you will need 18" wheels for the 6-pots (the cayenne brakes are a reasonably straight forward fit onto B5 RS4 discs)
Im currently running 19" bbs ch's, with spacers so there shouldnt be a problem with space to fit them.
I was assuming that the b7 set up would be a good one, but sourcing them seems a pain?
RE: Re: RE: Just bought S4, couple of minor issues!!
Posted: Wed Jul 08, 2009 3:15 pm
by ShaneyB
Your spacers could bitted poorly? I had this recently and it felt similar. May be wth checking. What size spacers are they?
Posted: Wed Jul 08, 2009 3:16 pm
by ShaneyB
Sorry, could be fitted poorly...
Posted: Wed Jul 08, 2009 4:55 pm
by philipwalker
The 19" CH`s have less caliper space than the 18" CH`s
18" CH`s 8.5x18 et35mm will fit directly over the B7 set up.
Posted: Fri Jul 10, 2009 12:06 pm
by PretendPorsche
Ah right, well thats weird hey, i took them off my b5.5 passat, i dont remember the offset but i think its different anyway.
Any ideas where to get a b7 setup or just sit it out and wait for some to come up, my discs are quite bad front and rear so i need to do it asap, and i dont want to spend out on discs twice!
Other thing is, on the rears, can i retain the caliper but just put an a8 disc on there with an a8 bracket, that the best idea?
Posted: Sun Jul 19, 2009 2:42 am
by ogg14
With the brakes pulsating... Try the rear/front passenger side ABS ring... or hub... Thats what was wrong with mine when i had that problem. The ABS ring was cracked. You will need to replace the whole hub... I think... and its an exchange part.
Andy
Re: RE: Re: RE: Just bought S4, couple of minor issues!!
Posted: Sun Jul 19, 2009 10:24 am
by grizz
ogg14 wrote:With the brakes pulsating... Try the rear/front passenger side ABS ring... or hub... Thats what was wrong with mine when i had that problem. The ABS ring was cracked. You will need to replace the whole hub... I think... and its an exchange part.
Andy
It's only a cv joint that goes .Easy fix.
RE: Re: RE: Re: RE: Just bought S4, couple of minor issues!!
Posted: Mon Jul 20, 2009 10:11 am
by PretendPorsche
Ah ok, so i should get the cv joint checked out?
Whats the talk of the abs sensors not being in right causing a similar problem, is that not correct?
Thanks.
