Rubbing brake pads
Posted: Sun Jun 14, 2009 2:49 pm
by bops4
I have just replaced the front rotors 360 x 32mm and pads DS2500 today, the only concern is the drivers side was a bit tight on the disc and slightly rubbing when driving. I`m taking it very gentle hoping they loosen off, is this going to overheat new pads and glaze them or should i try something else?
RE: Rubbing brake pads
Posted: Mon Jun 15, 2009 10:08 am
by Trig
Sticky caliper?
Posted: Mon Jun 15, 2009 1:18 pm
by bops4
Afraid not, the calipers are only couple of years old and i pushed all 6 pistons in with my fingers.
Posted: Mon Jun 15, 2009 1:54 pm
by dazzer
bops4 wrote:Afraid not, the calipers are only couple of years old and i pushed all 6 pistons in with my fingers.
Have you bled the brakes?
Posted: Mon Jun 15, 2009 4:34 pm
by bops4
not yet, was planning on doing that soon as overheated old brakes and had quite bad fade on the pedal.
Posted: Sun Jul 05, 2009 1:40 pm
by bops4
An update with new problems. The pads stopped rubbing soon enough but now i have a couple of issues. Fisrtly when cruising at about 75 for no apparent reason i`m occasionally getting a vibration which feels like badly balanced wheels, if i slow slightly then build up speed again its gone. If i apply the brakes gently when this vibration is present i get quite bad judder on steering as if discs are warped. This judder is also present when just applying the brakes above 80 but not so bad. Also i`m getting judder when slowing down but only in the last few yards and braking softly. Does all this mean my new disc are knackered?
Posted: Sun Jul 05, 2009 7:56 pm
by Marshy
FWIW, these were the exact symptoms I had on my old BMW when I had a sticky caliper.
I know you say yours are quite new though... Is either wheel getting hot? (I mean too hot to touch hot - careful!)
Posted: Mon Jul 06, 2009 4:47 pm
by bops4
While bedding in pads the drivers side wheel was quite hot but nothing different now.
