Snub Mount and Phoelinetic spacers fitting ?
Posted: Sat May 16, 2009 6:48 pm
by s2rsman
Hey guys what's involved in fitting the above ?
i.e. How easy and what has to come off to achieve.
I'm about to get the cambelt done so wondered if this was the time to do a snub mount.
Also was going to order phoelinetics at the same time
but didn't want a huge labour bill to fit ?
Thanks.
RE: Snub Mount and Phoelinetic spacers fitting ?
Posted: Sat May 16, 2009 9:38 pm
by andybnwc
yes on the snub and pretty sure the intake spacer is straight forward
Posted: Sun May 17, 2009 12:42 am
by Blue_Thunder
Wouldn't bother with the phenolic spacers whilst the cambelt is being done as they can be fitted with the front end on the car.
re: the cambelt, are you aware of all the other bits you should get done at the same time, ie: thermostat, water pump, etc.
Posted: Sun May 17, 2009 8:44 am
by s2rsman
Yep cambelt kit, rollers,tensioners, water pump,gasket, thermostat.
On the spacers I'll wait till I've recovered from the cambelt,
can it be a diy job ?
Posted: Sun May 17, 2009 12:07 pm
by andybnwc
yes you dont have to move much at all
Posted: Sun May 17, 2009 3:14 pm
by s2rsman
Had a look round today while doing the spark plugs, seen the bolts for the inlets.
It is simply a case of removing the top end stuff and installing them ?
any sealant required ?
Posted: Sun May 17, 2009 11:26 pm
by jimbo1234567
no they come with gaskets. just remove the y pipe, fuel rail and inlet manifold .should take 2 hours tops
