steering squeek
Posted: Thu Mar 26, 2009 8:27 am
by Nodds
When turning he steering wheel there is a squeeking/ rumble noise that sounds like its coming from behind the dash
Any ideas whats causing this
Nodds
RE: steering squeek
Posted: Sat Mar 28, 2009 11:53 pm
by bobbler
Full lock? I found ours is the power steering fluid had run low - which was actually caused by a leak in the pipes by the cooler bit.
Posted: Wed Apr 08, 2009 12:43 pm
by Nodds
No not on full lock, just when you turn the wheel slightly, usually on start up, just as you are pulling away, not always there either which is a pain
Posted: Sat Apr 11, 2009 5:56 pm
by Trig
Nodds wrote:No not on full lock, just when you turn the wheel slightly, usually on start up, just as you are pulling away, not always there either which is a pain
Squirt a load of silicone spray down the column, could be catching the cover or the top bush could be dry.
