Un-Official Audi tool No.7
Posted: Wed Feb 11, 2009 2:10 pm
by Mac_Xpert
When you round off the head of the Audi S4 B5 Hub Bolt...
...Turn to Un-Official Audi tool No.7 :D
Anyone else had to use 'Un-Official' tools on their car?
RE: Un-Official Audi tool No.7
Posted: Thu Feb 12, 2009 12:47 am
by imolas4uk
yeah i like that,a bit of heat from the welder helps aswell,hope that wheel bearing didnt get to hot,or is that why the hub bolt had to come off ?
Posted: Thu Feb 12, 2009 11:47 am
by Mac_Xpert
Luckily Wheel bearing replacement was why it came off. Did lower bushes at the same time as i had to cut one of the camber bolts out.
Posted: Thu Feb 12, 2009 7:18 pm
by stapo69
I have a special chopped, grinded and adapted long 17mm spanner for getting the passenger side egt sensor tight as space is a bit limited! As well as that anther ut down spanner to get to the bolts at the top of my main cts. Also I took my passenger rear wheel ff the other day and found a socket still wedged on the hub nut! Dunno how long hat'd been there!
Posted: Sun Feb 15, 2009 2:18 pm
by Doug_S2
i have a toolbox full of cut,bent and right angle lumps of metal for special tools!
Well saved!
Posted: Mon Feb 16, 2009 12:05 am
by Bluebrakes
Not on my s4 but I have had to make all sorts of special tools for my bikes.
A tool to hold clutch basket whilst you undo the bolts, which is simply a long handle and two bolts welded on.
A tool to remove the stupid honda locking nut on clutch baskets. I can't think why they would use this type of nut other than to prevent the home mechanic doing it themselves.
Posted: Mon Feb 16, 2009 12:35 pm
by rikrose
To get to one of the nuts in a SR18DET engine for changing a turbo gasket, the recommended method is to remove the engine. The real method is to take a spanner, heat it up where the neck meets the tool part, and bend it fifteen degrees. Every 200SX owner in the countr that works on their own car has one of these tools in their toolbox.
Posted: Wed Feb 18, 2009 12:31 am
by grizz
I've got a nice big 1" air gun for removing the drive shaft bolts .....
Posted: Wed Feb 18, 2009 1:53 am
by tartan_rob
Hammer, chisel or angle grinder. Doug will vouch.
Posted: Mon Feb 23, 2009 9:41 pm
by KayGee
My dad once changed the clutch in a tractor with a hammer chisel and a pair of water pump pliers.
After that they re-instated the "replacement of any broken tools policy" they withdrew the week before.
:twisted:
