Boost on RS6 turbos
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
pauloM
Boost on RS6 turbos
Post by pauloM » Sun Jan 25, 2009 3:20 am
Hello
I have RS6 turbos form Vast Performance and I would like to know how much boost can be used before destroy the original rods :)
I´m using 1.5 bar and don´t know how much power my car has, as the nearest 4x4 dino is 450 km away from my home.
The car has RS4 intercoolers , Siemens 630cc and Unichip
Anyone has this config or knows the power generated ?
Vast says the limit to rod is 550 hp. Is it BHP or WHP
Thanks !
Blue_Thunder
RE: Boost on RS6 turbos
Post by Blue_Thunder » Sun Jan 25, 2009 12:50 pm
You can't measure a car's power by boost alone. There are many other factors which can alter the power, ie: fuel quality, fuelling, timing, volume of air being used (MAF reading), etc.
I would contact Vast and see what they recommend that the boost is limited at.
Would also recommend you upgrade your intercoolers to get the most out of those turbos.
dazzer
Post by dazzer » Sun Jan 25, 2009 1:02 pm
I think torque should be your first concern!
JonnyX
Post by JonnyX » Mon Jan 26, 2009 11:09 am
Indeed. You should be OK on standard rods to around 500ft/lb (~670NM)
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
pauloM
Post by pauloM » Mon Jan 26, 2009 2:29 pm
Ok JonnyX
That´s what I wanted
But you mean 670 NM at whell or motor ?
Blue, I think upgrade over rs4 intercoolers a complicated issue. All new routes for so many tubes. After new rods this should be a must :)
I had that RS6 RS4 hybrids, and they start loosing performance, and some oil in the cold side.
Change for the RS6 from Vast and mapped to 1.5 bar.
As I don´t intend to open motor to change rods this year, I´m looking for this limits and try to leave it all working.
When mapped to 1.2 bar I got 540 NM - motor - with .77 A/F.
Then I changed to 1.5 bar and the A/F touch .94 .
New injectors coming in 3 days :)
Thanks for help !
pauloM
Post by pauloM » Mon Jan 26, 2009 3:03 pm
sorry for the whell :)
S4
Post by S4 » Mon Jan 26, 2009 6:58 pm
Are you using a MBC manual boost controller? or an electronic one. .77.........thats not good.
Darren
pauloM
Post by pauloM » Mon Jan 26, 2009 8:09 pm
I use Unichip. Very easy to make all work.
That´s 0,77 lambda , not mV ( too rich )
The story is simple...I changed turbos and adjusted boost 450 km away from my home and 850m alt without changing injectors. So I decided to use less boost just to go home. At local dyno, got that 0,77 1.2 bar.
After getting home, I used a trackday to get a better AF ratio and do some tests. Finally I decided to use 1.5 bar and buy new injectors, as with the actual injectors, I got 0,94 AF ratio lambda ( too poor )
Mikse
Post by Mikse » Thu Feb 26, 2009 11:59 am
PauloM, Interresting setup you have. Do you have any intake mods like manifold or heads/cams? When those rs6 turbos start to make boost/power? I´m thinking of same kind of setup but I`m worried about the lag.
2001 S4 Avant
pauloM
Post by pauloM » Wed Apr 15, 2009 2:28 pm
Hello Mikse. Sorry I haven´t seen that.
I there´s nothing extra, except all tubes from RS4 APR kit.
Today I´m running the car with siemens deka injectors @ 4 bar ( some like 70 lbs )
It´s running like the old RS4/RS6 turbos, almost no lag. But as I didn´t change rods, I decided to make a remap that should never go over 1.5 bar.
Boost gets 1.5 at 4000 rpm and stays there until 7000 rpm.
There´s a good sensation of never ending power when we don´t use overboost :)
Some day I´ll put at youtube the rpm and boost.
Today I´m having trouble with boost as went to trackday and changed the air filter to K&N and a almost complet free flow exhaust. It´s getting 1.8 bar.
So I´m thinkin of a MBC to permit a fast control of the boost without remap everytime I change exhaust.
And I think I´ll have to make holes at the air box as the tubo after MAF gets "sucked" sometimes !
Blue_Thunder
Post by Blue_Thunder » Wed Apr 15, 2009 3:50 pm
pauloM wrote:And I think I´ll have to make holes at the air box as the tubo after MAF gets "sucked" sometimes !
Some people are replacing their accordian hose with silicon tubing to prevent this collapse.
pauloM
Post by pauloM » Wed Apr 15, 2009 6:17 pm
I´d to solve this using 3M tape and hose clamps. Ugly :)
Did not find any silicone tube that could fit.
Mikse
Post by Mikse » Fri Apr 17, 2009 10:33 am
pauloM wrote: It´s running like the old RS4/RS6 turbos, almost no lag. But as I didn´t change rods, I decided to make a remap that should never go over 1.5 bar.
Full boost at 4000rpm, that seems quite a late or is it tuned that way to spare the rods? At what rpm it start to pull? Just for comparison my K04 starts to make useable power @ 1800-2000rpm and full boost 1,4bar comes ~3000rpm.
2001 S4 Avant
pauloM
Post by pauloM » Fri Apr 17, 2009 2:54 pm
Yes, it´s working this way as I mapped to do so.
When I wrote the car was getting > 1.8 bar ( 4 posts up ) it happened @ 3000 rpm. I did´t try harder to see how much I could get :)
Yesterday I mounted the APR full exhaust and 1.5bar @ 4000 returned.
But the start point I´ll have to answer later...
This is a video with the ex RS4/RS6 turbos
Have to be at home to put the link :)
Reading old posts, I decided to drill some holes on the air box! Maybe this is the problem with the MAF hose.
Thanks for all help !
pauloM
Post by pauloM » Fri Apr 17, 2009 8:00 pm
