Fitting RS4 (B5) brakes
Posted: Fri Jan 02, 2009 11:52 pm
by reserves
I've got hold of a complete B5 RS4 brake set up and am looking forward to getting these on my facelift 2000 S4.
Do I need anything except the, calipers, carriers, hoses, & pads?
I can't find a fitting guide anywhere and I've read that some people need to extend or replace the handbrake cable?
Also I've read that some people have replaced the brake hoses? Is this out of choice or is it necessary?
Is it a hard job to swap these for a competent mechanic, how many hours are we talking?
Any answers much appreciated.
RE: Fitting RS4 (B5) brakes
Posted: Sat Jan 03, 2009 9:02 am
by okkim
No you don't necessarily need anything else.
The front is easy, just bolt in.
In the rear, you have to use RS4 brake cables, or "stretch" the old one by sliding it back a little. To do that, you have to press the black support thing's lock clips which is in the control arm and pull the cable back.
The install wont take many hours, maybe two or three.
Posted: Sat Jan 03, 2009 11:45 am
by reserves
Thanks Okkim, where is this black support clip that you talk about, on the rear caliper?
Posted: Sat Jan 03, 2009 9:15 pm
by UKS4APR1
I assume you have 18" wheels to fit over the new Front brakes.
As okkim has told you, "press the black support thing's lock clips which is in the control arm and pull the cable back"
When I did mine I got hold of some new RS4 cables which are longer and fit perfectly.
Do you have the RS4 backplates for the rear? The S4 ones will be too small or you can run without.
Posted: Sun Jan 11, 2009 3:31 pm
by Bluebrakes
how much are the RS4 hand brake cables?
do you have a part number?
Posted: Sun Jan 11, 2009 8:23 pm
by UKS4APR1
Bluebrakes wrote:how much are the RS4 hand brake cables?
Part Nos. 8D0609721T and 8D0609722F
About £30 each
Posted: Sun Jan 11, 2009 8:43 pm
by Bluebrakes
Thanks!
Posted: Sun Jan 11, 2009 8:47 pm
by Bluebrakes
you wouldn't by any chance know the part numbers for the back plates too?
