H & R coilovers for B5 is the damping adjustable?
Posted: Mon Dec 08, 2008 2:39 pm
by gareths4
hi, can anyone tell me if its possible to adjust the damping on the H & R coiloves for the B5 S4 and how to do it as i can't see any obvious adjustment. thanks
RE: H & R coilovers for B5 is the damping adjustable?
Posted: Mon Dec 08, 2008 3:08 pm
by JonnyX
Not unless you have the H&R PCS coilovers. They are rebound adjustable only. Standard H&R are ride height only.
Re: RE: H & R coilovers for B5 is the damping adjustable
Posted: Mon Dec 08, 2008 3:57 pm
by gareths4
JonnyX wrote:Not unless you have the H&R PCS coilovers. They are rebound adjustable only. Standard H&R are ride height only.
thanks, are the standard H & R coilovers considered to be good? I feel the ride is quite bouncy and they are not too old so should not be worn out yet.
can anyone recomend a set up with good ride maybe a little firmer then standard that is not bouncyl. Don't really want anything stupidly low.
RE: Re: RE: H & R coilovers for B5 is the damping adjust
Posted: Mon Dec 08, 2008 9:20 pm
by S4INT
Try adjusting the H&R ride height up - made a huge difference to the ride quality on mine.
Failing that, the Bilstein PSS9 setup is superb and very comfortable on the "comfort" setting.
