EGT DTC code and System too rich problem
Posted: Wed Oct 01, 2008 10:37 am
Hi everyone,
I am having problems on my B5 S4 with the yellow engine management light appearing.
This started just before my 80k service so while it was in QST for the service they took a look and said it was logging a fault running rich and replaced the diverter valves (for the more expensive hyperboost ones as thats all they had in stock and I was keen to get my car back quickly)
However the light came back so I bought a cheap ebay vag-com cable and can see that 3 faults are being logged, 17537, 17862, and 17535. When they are cleared they come back again within a few days normally, though never immediately.
The logs are shown here:
******sep30 2008*****
VAG-COM Version: Release 409.1-US
Control Module Part Number: 8D0 907 551 G
Component and/or Version: 2.7l V6/5VT 0002
Software Coding: 10711
Work Shop Code: WSC 63351
Additional Info: WAUZZZ8DZ1A139188 AUZ7Z0A1797563
3 Faults Found:
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
P1129 - 35-00 - -
17862 - Exhaust gas temperature sensor short 1 to ground
P1454 - 35-10 - Please Register/Activate - Intermittent
17535 - Long Term Fuel Trim mult.,Bank1 System too Rich
P1127 - 35-00 - Please Register/Activate
******* Sep 31 2008 *********
3 Faults Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-10 - - - Intermittent
17537 - Long Term Fuel Trim mult.,Bank2 System too Rich
P1129 - 35-00 - Please Register/Activate
The car is a late jun 2001 model and standard with no remap. It has the hitachi MAF which I believe is less likely to go wrong from reading other posts here. The car doesn't feel down on power and when Kim the guy from QST drove it he said it felt like the power was good too.
I plan to get in contact with QST again but I know there are a lot of experts on this forum so wanted to get some advise here first.
If anyone can help with the following questions it will be much appreciated:
1/ Is driving the car in its current state likely to cause it any permanent harm ?
2/ Is the system too rich error likely to be caused by the EGT sensor problem or are they probably two seperate problems.
3/ From searching other posts it appears that EGT 1 is the drivers side and it looks easy enough to change, please can someone confirm this and also whether this is the black one (078919529F) or the red one (078919529G) as the vagparts site refers to them as LH and RH but that depends on which way you are looking at the engine !
Thanks in advance for any help.
John
3 Faults Found:
P1129 - 35-00 - -
3 Faults Found:
John
